Rear-end Thumping
Old Mar 15, 2011 | 06:59 PM
dunacn1's Avatar
dunacn1
Question Rear-end Thumping
I have a 2004 F150 4x4 5.4. Over the last few weeks i'v noticed that when the truck has been parked for even a short time, when I start to move out I am getting a thumping noise from the rear, almost sounds and feels as though I am driving over small speed bumps, but once i get going it seems fine. Any ideas where to start?
Old Mar 15, 2011 | 08:25 PM
70f100longbed's Avatar
70f100longbed
Sounds like the limited-slip clutches. Add 2 bottles of Ford friction modifier XL-12 to the rear end and drive in circles for a few mins. If that doesn't help then its time for new clutches.
Old Mar 17, 2011 | 09:59 PM
stx4x4's Avatar
stx4x4
ford frixtion modifier xl-12
question im thinking im having same prob, where to we add this modifier to ?
can you explain please how it is that you did it ? thanks
Old Mar 18, 2011 | 08:07 PM
70f100longbed
The easiest way is to pull the rear speed sensor at the top of the diff and pour it in.
Old Mar 18, 2011 | 08:13 PM
03r1's Avatar
03r1
It is not the clutches if you are pulling out in a strait line. The clutches only break loose from each other when turning. So if you are turning slightly when this is happening i would say that is what it is. I have the same thing going on.
Old Mar 20, 2011 | 09:32 AM
baitmaster's Avatar
baitmaster
I have had other vehicles that this has happened in. However, at the time, I dumped the entire rear end, and then the modifer with the new gear oil.
christyj
20
Dec 15, 2014 11:33 AM
gearjammer69
16
Aug 4, 2014 09:57 AM
nothingbutford46
1983 - 2012 Ranger & B-Series
Jun 14, 2013 10:04 PM
iron1951
28
Sep 16, 2010 06:47 PM
scar98
Oct 31, 2005 09:21 AM
