alternator issues
Old Mar 11, 2011 | 05:40 PM
frenchy107's Avatar
frenchy107
alternator issues
89 f150 with a 4.9l, just completely rewired the alternator harness going to the started solenoid, still having some issues charging. not putting out 14 volts. any suggestions??
Old Mar 11, 2011 | 05:58 PM
rla2005's Avatar
rla2005
Do you have exciter voltage on the Light Green/Red wire with the key on?
Old Mar 11, 2011 | 06:20 PM
frenchy107's Avatar
frenchy107
the wires were already replaced once before, not factory colors. went wire to wire the way it was
Old Mar 11, 2011 | 06:31 PM
rla2005's Avatar
rla2005
I will ask the same question, Do you have voltage on the exciter wire with the key on? Use a meter to measure it.
Old Mar 11, 2011 | 06:38 PM
frenchy107's Avatar
frenchy107
ill have to check tomorrow. no garage or light at the moment
Old Mar 11, 2011 | 06:49 PM
rla2005's Avatar
rla2005
I just did a 3G upgrade on my '92 F350. It had a crappy fire-prone 2G in it from the factory. There is a connector near the battery for the exciter wire on my truck. If your truck has the same connector it could be a source of trouble for you.
Old Mar 11, 2011 | 06:57 PM
frenchy107's Avatar
frenchy107
ill look into it, thanks a bunch
