oil temp / coolant temp
Old Mar 15, 2011 | 03:58 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by dchamberlain
You can maintain or not maintain your truck however you like, I don't particularly care. However, no amount of "feather footing" or slow driving should cause your coolant temps to drop the way you described. It is indicitive of a thermostat that is not operating properly.
Agreed. His thermostat is faulty if it's not maintaining 185 or better. I don't give a damn how many miles he drives at 25 it shouldn't drop to 175. If by flooring it his temps rise rapidly then he probably has headgasket issues.
Old Mar 15, 2011 | 04:07 PM
bpounds's Avatar
bpounds
Yep, sorry to say, that thermostat is not closing.
Old Mar 15, 2011 | 04:14 PM
npccpartsman
Originally Posted by XB70
Your previous post referenced frigid weather. Now, it's +25F - +35F. So, you don't think there's a big difference between -20F and +25- +35F????? That's only 45 to 55 degrees apart.
1. My cooling system is in better condition than yours. Perhaps you need to take a closer look at your cooling system.
Made the same trip today in +59F weather. Coolant reached 198F flooring it from 50 -70 MPH on the highway with oil at 201F. Oil temperature was 194F and water was at 191F in my driveway because I floored it up a 7% grade 1/2 mile from home.
In case you can't read between the lines, I think online diagnosis of any problem is 50% guessing. When it involves driving style, weather, route, etc., it becomes 96% guesswork. If you think a 55F difference in outside temperature is not material, it's 99.98% guessing. I think.
My truck didn't have any problem maintaining 190 at 0* F and has no problem maintaining 190 at 80* F. It only ran 200 with a BAD thermostat last summer when the NOAA temp's were 105* (in the shade) and blacktop temps were 140*+.
Old Mar 15, 2011 | 05:14 PM
ljutic ss's Avatar
ljutic ss
Do yourself and the truck a favor and change your thermostat, and something else is wrong with your truck or the gauges that are giving you these readings. Going from 50 to 70 is a matter of a few seconds, at least it is in my truck, no way in hell would I get these high readings you posted.
cory5517
May 25, 2016 10:20 PM
donovan
6.7L Power Stroke Diesel
15
Jun 18, 2013 04:04 PM
05 f250 6 inch lift
Jul 17, 2012 01:15 PM
teppler
Feb 10, 2010 11:52 AM
yz400f
Dec 1, 2009 02:08 PM
