Neutral>Drive Jump
Old Mar 14, 2011 | 04:25 PM
pit_of_pity's Avatar
pit_of_pity
Neutral>Drive Jump
Whenever I pull up to a red light, I always put the my 2wd 390 AT into neutral. Pressing the brakes down firmly and shifting into Drive, the truck always knocks, lunges up. Sometimes more noticeable than other times. Less when its warmed up. Is this normal? Could it be my engine mounts?
Old Mar 14, 2011 | 07:27 PM
tmcalavy's Avatar
tmcalavy
Could be
the motor mounts. Stand off to the side of the truck while it's running, hood open and have a bud work through the gears...just like you're at a light. If it jumps up or down, check the mounts. Why do you slide it into N there...does it want to die at idle?
Old Mar 15, 2011 | 08:48 AM
pit_of_pity
It idles fine. Just put it in neutral as a habit. Used to have overheating issues in the summer and by putting into neutral increase fan speed. Thanks, will look into the mounts.
Old Mar 15, 2011 | 12:07 PM
78 PEB's Avatar
78 PEB
Could be your idle speed is too high............
Old Mar 15, 2011 | 12:57 PM
pit_of_pity
Idles at 500 in gear
Old Mar 15, 2011 | 01:10 PM
OLE_FORD_TECH's Avatar
OLE_FORD_TECH
Neutral idle? 500 in gear is low,650-750 i think would be the norm.But i would take a look at the mounts.
Old Mar 15, 2011 | 01:22 PM
78 PEB's Avatar
78 PEB
Yeah, look at the motor and trans mounts..............
Old Mar 15, 2011 | 01:34 PM
68horses's Avatar
68horses
Hey Phil,
Glad to see you found this place/site. A lot of good folks, good info and a lot of "green-horn" types of questions that a fellow with your experience and wisdom will certainly be a welcome addition. Good to see another M&Mer. They wouldn't let me keep my horseb---z user name here.
Gene
Old Mar 15, 2011 | 07:07 PM
tmcalavy's Avatar
tmcalavy
500 is right in gear at idle...650 at N idle
Old Mar 15, 2011 | 08:39 PM
pit_of_pity
Alright, checked the motor/transmission mounts and did not see anything out of the norm. Upon further inspection, the "lunging" starts right when the drive shaft engages the diff. Substantially more in N>D than N>R. Maybe just the nature of the beast.
Old Mar 17, 2011 | 02:23 PM
OLE_FORD_TECH
Originally Posted by 68horses
Hey Phil,
Gene
Hey Gene,
I was just lurking around and noticed that i joined here in 08,so i just logged in and joined the discusion.M&M seems to be alittle slow lately.Trucks are a change of pace as it is a big part of Fords history and mine.Most of my years were spent under the hood of these beauty's.
Phil
Old Mar 17, 2011 | 03:50 PM
78 PEB's Avatar
78 PEB
Might want to look at the backlash in the ring and pinion. Chock the wheels, Put the truck in neutral, crawl under and see how far you can turn the driveshaft either direction before it stops. Let us know what you find............
2FordTrucks
Jun 19, 2022 08:29 PM
bthr22
Aug 25, 2013 05:23 PM
Fox Fader
1997 - 2003 F150
Mar 1, 2011 03:00 PM
Cracker289
Jul 19, 2010 05:46 PM
skonnie-mark
Sep 17, 2007 12:56 PM
