Noob needs Vin# help
Old Mar 14, 2011 | 08:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Gun-nut27
Are the Dana 60.2(3) rear ends any good? I've never heard of them before.
In their day, both were very good. Today, both are a liability because replacement parts are difficult to find, especially the axle shafts.
None of the Dana 60.2/60.3 parts are shared with Dana 60's.
Old Mar 14, 2011 | 11:40 PM
The Masked Rider's Avatar
The Masked Rider
Gun-nut, as for it maybe being a 428, pull one of the plugs and check the stroke. Also, the 428 has a flywheel (auto or standard) that is specific to that motor. Check the #s on the flywheel and check the balance weight. That is a dead give away unless they spent around $500 to have it internally balanced (crank).
I'll bet ND will have some #s for ya and maybe a picture or two of the flywheel.
Old Mar 15, 2011 | 08:14 AM
Gun-nut27's Avatar
Gun-nut27
Would I be able to check this with the motor mounted?
I removed the bottom portion of the bell housing(?) the other day, but I didn't look for any numbers.
Old Mar 15, 2011 | 10:03 AM
NumberDummy
Measuring the stroke will be the easiest method: 428: 3.98"
There are several possible 428 flywheels, but Ford used a rubber stamp for ID number markings, most have worn away today.
nastar44
1966 - 1977 Early Broncos
Jun 3, 2011 08:51 AM
tattooman
May 17, 2010 10:28 AM
glanzer_51
Jun 11, 2007 12:59 AM
redneckchuck
New Member Introductions
Feb 11, 2007 07:14 AM
taintore
Jan 11, 2006 02:56 PM
