Mod question?
Old Mar 13, 2011 | 07:19 PM
r-kid's Avatar
r-kid
Mod question?
I will be doing the uvch (50 cent) and re torque should I do the frx and hpx at the same time ? Will I will be duplicating efforts if I do them seperate ? Also what shocks and steering stabilizer do you guys recommend ? thanks
Old Mar 13, 2011 | 08:07 PM
clintbonnie's Avatar
clintbonnie
I would do everything at once.. here is the 50 cent link again in case you don't have it..
https://www.ford-trucks.com/forums/8...ck-shakes.html
Old Mar 14, 2011 | 01:16 AM
timmyboy76's Avatar
timmyboy76
hpx takes 5 minutes... If/when installing the FRx, i'd get a fuel bowl o-ring kit, then you can install the FRx on the bowl while its out, so ur not fightingthe spring location.
If anything, looking to do some mods, while diving into the 50 cent mod, i found it easy to remove the IC pipes, and with those out, do the foil delete, plus it makes it SO MUCH easier to remove the covers.
Old Mar 14, 2011 | 09:27 AM
Mitch1407's Avatar
Mitch1407
sorry Foil delete does... what exactly?
Old Mar 14, 2011 | 09:58 AM
clintbonnie
I believe it just makes it so you can "heard" your turbo whine a little louder..
Old Mar 14, 2011 | 12:02 PM
r-kid's Avatar
r-kid
Thanks for the info
Stinkweed14
6.4L Power Stroke Diesel
Feb 18, 2012 11:00 PM
jerseybmc
1997 - 2003 F150
Mar 9, 2010 07:38 AM
78ford351m
47
Feb 17, 2009 02:11 PM
HookedOnFuel
34
Jun 8, 2008 08:09 AM
motobub
User Gallery & Picture Display
Jan 9, 2003 01:16 PM
