Leaking Valve Cover 1969/360
HI All!!
I have a 1969 F250 Camper Special with a good running 360 in it...but the valve covers leak. There are raised areas on both ends of the head where the valve cover attaches/seals. When the valve cover gasket fits over this raised area it leaks.
The raised area (bump) is just below the valve cover bolt holes.
I want to file that area smooth but I am not sure what function the 'bumps' have.
Is there a purpose for the raised bumps? Should I file them smooth?
Thank You!
Thank You!
OP... add some extraining RTV to that area and let it set before exposing it to engine heat and hot oil... it'll get you by for now because the correct way to fix the height difference is to have the intake machined....
I believe you are mistaken... the OP is referring to the parting line between the head and the intake manifold.
HIO is talking about the actual intake sitting higher then the top of the head while I was talking about the tips of the intake gaskets sticking up higher the the head and intake surfaces.
Appreciate the info...
I took the file to it and - yes it is the gasket between intake and head - I thought it was a parting line at first too.
The head does sit higher then the intake so RTV will be needed to get a good seal in that area.
This must have been a problem for a long time, the bottom of the engine/chassis is loaded with oil from years of leaking. (I just bought is last fall)
Thanks for the input - I needed it!!
Definitely need a dab of RTV over that intake gasket. If you're using stamped valve covers then I like a thin bead of RTV underneath and on top of the valve cover gasket. A set of spreader bars doesn't hurt either. Stamped valve covers are just dang hard to seal. For choice of sealant, I like Ford's TA-31. It seals well and yet it's easier to remove than some RTV products. It's kind of expensive but worth it and can be found on Amazon or Ford dealer.
https://www.summitracing.com/parts/fel-es72676
68FE390
17
11-03-2007 03:09 AM
Jrock909
16
10-13-2006 12:01 AM
FERacing66
24
01-14-2005 01:11 PM
