scangauge ?s
It can't read fuel pressure. There is no fuel pressure sensor on a 6.0 and must be added for whatever monitoring system you use.
There are simply too many parameters for me to list. You can program 25 "X" gauges in addition to the standard package that's included. Boost is read as MAP pressure and you'll have to subtract approximately 15 from the displayed value to get boost. It's definitely worth the price and FAR better than anything from the factory.
Here are the 3 different sets of parameters for the FICM posted by Robs97z28 in another thread.
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
<ACRONYM title="Fuel Injector Control Module">FICM</ACRONYM> Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
<ACRONYM title="Fuel Injector Control Module">FICM</ACRONYM> Main Power (Volts) (Should be 47-48)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP <!-- / message -->
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
