scangauge ?s
Old Mar 13, 2011 | 11:24 AM
BobsF350's Avatar
BobsF350
scangauge ?s
can it read boost/oil temp/fuel pressure/trans temp
what does it read and give a value for??
Old Mar 13, 2011 | 11:42 AM
npccpartsman's Avatar
npccpartsman
It can't read fuel pressure. There is no fuel pressure sensor on a 6.0 and must be added for whatever monitoring system you use.
There are simply too many parameters for me to list. You can program 25 "X" gauges in addition to the standard package that's included. Boost is read as MAP pressure and you'll have to subtract approximately 15 from the displayed value to get boost. It's definitely worth the price and FAR better than anything from the factory.
Old Mar 13, 2011 | 12:40 PM
BLADE35's Avatar
BLADE35
love mine too just put in the x-gauge for ficm main power seems to be working 48-49 volts going to do the other ficm 12 volt codes stuff today.
I also programmed that vgt and it does register something but what?
Old Mar 13, 2011 | 12:42 PM
BobsF350's Avatar
BobsF350
whats the x gauge and how much more is that
Old Mar 13, 2011 | 12:55 PM
BLADE35's Avatar
BLADE35
x gauge comes with it at no extra charge go to the scan gauge web site and check them out they are great it will moniter up like 35 things. 25 of those are an x-gauge all that means is x gauge are the ones you program in off the list specific for your vehicle
Old Mar 13, 2011 | 12:57 PM
BLADE35's Avatar
BLADE35
try this
ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
Old Mar 13, 2011 | 01:59 PM
BLADE35's Avatar
BLADE35
has anyone else tried the new ficm programming and vgt programming for the scan gauge
Old Mar 13, 2011 | 02:54 PM
roadrunner01's Avatar
roadrunner01
it can also be programmed to read boost, i've had it in mine for over a year, i'll have to go look up the protocol and re-post
Old Mar 13, 2011 | 03:18 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I would appreciate that. What year is your truck?
Old Mar 13, 2011 | 03:47 PM
roadrunner01
following is what I have programmed to read boost (BST)
686AF1010B
0441850B0000
2808
00910064FF88
my truck is an '07
Old Mar 13, 2011 | 03:52 PM
BLADE35's Avatar
BLADE35
686AF1010B
0441850B0000
2808
00910064FF88
my truck is an '07
thanks will try it out
And the reading that I get will be boost psi right?
Old Mar 13, 2011 | 04:39 PM
BLADE35's Avatar
BLADE35
those boost numbers worked great thanks again
Old Mar 14, 2011 | 04:24 AM
npccpartsman
I couldn't find any information on this. Clarification please?
Also, if anyone has programming for the fan speed sensor please post it up.
Old Mar 14, 2011 | 04:48 AM
roadrunner01
Below is the FICM main voltage (48 volt)
07E02209D0
0462450906D0
3010
006401000000
there are also two other FICM readings (12 volt) that I didn't bother with. The fan speed sensor I haven't seen as of yet. Updated on the Scangauge site is also Exaust Back Pressure and also VGT read as %.
Old Mar 14, 2011 | 05:44 AM
bubba_78363's Avatar
bubba_78363
Here are the 3 different sets of parameters for the FICM posted by Robs97z28 in another thread.
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
<ACRONYM title="Fuel Injector Control Module">FICM</ACRONYM> Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
<ACRONYM title="Fuel Injector Control Module">FICM</ACRONYM> Main Power (Volts) (Should be 47-48)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP <!-- / message -->
