Back Up Sensor Alarm
Old Mar 13, 2011 | 07:29 AM
InSearchOf's Avatar
InSearchOf
When the 4-Pin trailer connector from the trailer is hooked up to the truck, is the back up alarm supposed to automatically shut off when you put the truck in reverse?
Researching the owners manual, and manual did not specify unless I missed it.
Thanks,
Will
Old Mar 13, 2011 | 07:37 AM
sdetweil's Avatar
sdetweil
I think its only the 7 pin. The ground and brake additional signals make the difference.
Sam
Old Mar 13, 2011 | 07:46 AM
brmccolley's Avatar
brmccolley
Sensors still work when 4 pin used
I use the 4 pin for a RECON light bar and the sensors still work.
Old Mar 13, 2011 | 07:58 AM
sdetweil's Avatar
sdetweil
no. that wasn't what he was asking..
one of the complaints is that the backup alarm is BEEPING when you have a trailer connected. (My suburban turns them off for me)..
the 2011 is supposed to DISABLE the backup alarm automatically when you connect a trailer.
He is reporting that when you use the 4 pin connector, the alarm is still active.
| Maybe you are saying, "still working with the 4 pin here as well"
Sam
Old Mar 13, 2011 | 11:25 AM
InSearchOf's Avatar
InSearchOf
Sam
Good Afternoon Gents,
Thanks for the replies!! My trailer just has the 4-Pin connector, and when I have everything hooked up and the trailer plugged in, I still get the back up warning from the sensors when backing up......not a big issue, since I can easily turn it off when it comes up on the display......was just wondering if this was normal operation.
Thanks Again!!!!!!
Will
Old Mar 13, 2011 | 03:35 PM
Rambro4's Avatar
Rambro4
Thanks Again!!!!!!
Will
How do you. Turn it off? I know my 05 and 08 each had a button on the dash to disable it but I haven't noticed how to do it on my 2011
Old Mar 13, 2011 | 03:40 PM
sdetweil's Avatar
sdetweil
you have to scroll thru the dash information display
sam
Old Mar 13, 2011 | 05:44 PM
Rambro4's Avatar
Rambro4
sam
Alright thanks I'll try it
Old Mar 13, 2011 | 06:33 PM
ctownson's Avatar
ctownson
It comes up on the display and you just select the disable option.
Old Jul 11, 2011 | 08:05 AM
JuniorDJ's Avatar
JuniorDJ
It comes up on the display automatically when engaged in R? (with the option installed of course...)
Old Jul 11, 2011 | 08:12 AM
JuniorDJ's Avatar
JuniorDJ
I see though that this is about the backup sensor - not the backup alarm that I was looking into...
Old Jul 11, 2011 | 10:39 AM
lakedweller's Avatar
lakedweller
The option to turn it off used to come up when backing up to a trailer but it doesn't now. Does anyone know how to get it back.....
Old Jul 11, 2011 | 11:13 AM
Marauder92V's Avatar
Marauder92V
There is another menu item that is available (under settings?). Could this be the master on/off?
Old Jul 11, 2011 | 06:21 PM
Davgt500's Avatar
Davgt500
When I have the boat hooked up (4 pin) I still get the back up sensor alarm and have to cancel via the steering wheel "ok" button. When I have my gooseneck hooked up (7 pin) the back up sensor alarm is set to off automatically.
Old Sep 2, 2011 | 12:28 PM
Motomonkey's Avatar
Motomonkey
I've actually found a way to 'fix' the reverse sensor beep. Keep in mind that this 'fix' permanently disables the beep but the rest of the sensor system works normally. The trick is to defeat the speaker for the beeper. If anybody has tried this, you may have noticed that Ford thought about that already- they made it where 'Check Park Aid' still comes up all the time if the speaker is unplugged.
My trick: I cut the wires at the speaker and hooked them to a small 12v LED. The LED doesn't light up, but it provides just enough resistance that the system thinks the speaker is good to go. As a result, there are no warnings in the display and the system works normally but quietly.
Of course, a real electrician could probably refine this 'fix', but all I had was an LED and a lack o patience. Feel free to spread the word. I'm not a member of any other forums and this seems to be a widespread problem. Hope it helps!
Yep
6.7L Power Stroke Diesel
24
Feb 19, 2017 05:55 PM
lindenj
Dec 16, 2016 02:01 PM
DeathRowe
May 8, 2006 05:38 PM
lghtningstruk
Jul 13, 2002 07:48 PM
