Transmission issue I think
Old Mar 12, 2011 | 10:40 PM
true blue's Avatar
true blue
Truck had a whining sound like a power steering pump (but it's not). I hear a growl like a wheel bearing that is related to vehicle speed and not engine RPM. I think these sounds are coming from the transmission. Figures. Had the truck for two months. I traded out of a 06 Dodge that broke down all the time to get stuck with this issue. I don't have the money. Any idea how long it will last? I have towed with it twice. I am pi$$ed. Truck has 115k.
Any advice is welcomed.
Old Mar 12, 2011 | 11:21 PM
true blue's Avatar
true blue
FYI- transmission functions perfectly.
Old Mar 13, 2011 | 11:38 AM
tdpower's Avatar
tdpower
Not sure but here is a bump. I wouldn't think a transmission issue. Maybe something in the driveline or front/rear axle.
Old Mar 13, 2011 | 01:09 PM
bigsteve1969's Avatar
bigsteve1969
mines doin the same thing but my trans is acting up a little every now and then
Old Mar 13, 2011 | 08:34 PM
true blue's Avatar
true blue
I guess I just need to save pennies and wait for the big boom. Meanwhile I will be scared to take my horses anywhere.
Old Mar 13, 2011 | 09:13 PM
Night Crawler's Avatar
Night Crawler
the whine, prolly is power steering, can you duplicate by turning wheel w/o moving.
the grinding could be front bearings, jack it up remove tires and caliper so you can fell only the hub bearings. jack up the rear, put in neutral and really check the U joints.
just to maybe help you think of better things to go bad.
Old Mar 13, 2011 | 09:14 PM
Night Crawler
good thing is you can just sadlle up a horse and ride it back to town.
Old Mar 13, 2011 | 11:08 PM
true blue's Avatar
true blue
LOL, so true!
Old Mar 13, 2011 | 11:12 PM
true blue's Avatar
true blue
Thanks. I do know the whining is not the power steering. I wish it was. It is not related to turning; only rpm's and shifts.
Old Mar 15, 2011 | 11:25 AM
true blue's Avatar
true blue
UPDATE: It's the rear end.
Well don't I feel like the north end of a south bound mule.
I opened my back window and I could hear the rear differential loud and clear.
I pulled the fill plug and it is covered in metal. The oil has metal flakes in it.
The tag says 3L73 (3:73 Limited slip) and a 10 5. I assume it is a 10.5 rear made by Sterling?
I am going to open it up this weekend and take a look.
How hard are these to rebuild? I think I am going to do it myself. I hope all I have to buy is the bearings and a new clutch kit.
Old Mar 15, 2011 | 11:49 AM
BillyBob69's Avatar
BillyBob69
The sound changes with RPMS and speed.... Torque converter? Alot cheaper than the whole tranny.
Old Mar 15, 2011 | 12:03 PM
joeyd61's Avatar
joeyd61
If bu chance all you need is ring and penion gears...PM me I can help you out..they came out of a limited slip 03, Sterling 10.5
