Sponsored by: Real Truck
Interior Lights
Old Mar 12, 2011 | 05:59 PM
cdvit664's Avatar
cdvit664
Interior Lights
Can anyone help,
The interior lights that usually dim out when the doors are shut will not turn off, which keeps killing my batteries and suggestions?
Old Mar 12, 2011 | 06:18 PM
dchamberlain's Avatar
dchamberlain
Is your door ajar indicator on the dash staying lit? If it is, one of your door switches is probably stuck. A liberal application of WD-40 to the door latch, followed by opening and closing the door to work the WD-40 in will usually loosen it up.
Old Mar 12, 2011 | 06:29 PM
cdvit664's Avatar
cdvit664
No light is not on and did the wd-40 trick and still not working. I tried the interior switch and you can see the lights get brighter when I turn switch on. Usually when I close the door they dim out but no luck now
Old Mar 12, 2011 | 06:37 PM
dchamberlain
It might be the interior light switch. I think if you unplug that switch it would eliminate it from possibility. Otherwise, I don't know.
What year, etc?
Old Mar 12, 2011 | 06:45 PM
cdvit664's Avatar
cdvit664
1999 F350 Dually
Old Mar 12, 2011 | 10:06 PM
brd7666's Avatar
brd7666
It could be your GEM Module is going bad. That is what controls the dome light.
jasonschwenk
Nov 21, 2006 06:58 PM
alanscott
Dec 19, 2002 06:18 PM
Franklin2
Oct 29, 2002 01:31 PM
FTE Ken
Jan 29, 2002 12:06 PM
