Sponsored by: Real Truck
fuel mileage
Old Mar 5, 2011 | 07:38 PM
Applebutter's Avatar
Applebutter
fuel mileage
hi guys, i need some help on somethings for my 2004 PSD F250 cc4x4. I need better fuel mileage only getting 12-13.5 around town (no hard driving). Im looking at putting a SCT SF3 tuner on it just going to be using it for towing and a round town driving and maybe some high performance once in awhile. My neighbor has done some research and said that i need to change the thermostat. Im running a AFE filter and Banks 4" catback monster exhaust.
Old Mar 6, 2011 | 12:08 AM
8lug's Avatar
8lug
You should get rid of the air filter and return it back to the stock filter it is a better filter. A Scangauge II would be a good investment. It has 24 digital gauges and scans for trouble codes. You probably do need a thermostat as my truck was running at 170 degrees and knocked my fuel mileage down to 12 and 13 mpg. I changed the thermostat and now my Scangauge is reading 190+ which is the operating range plus I am able to keep an eye on the engine oil temp which should run no higher then 15 degrees over the coolant temp. These two temp readings need to be monitored so your EGR cooler does not have a melt down . I also got the latest PCM,FICM,TCM computer flash at the dealership and now I am getting 17.5 mpg in my crewcab dually that is up from 14 mpg. I also have the Scangauge set on instant mpg so I can really squeeze more out of each gallon. This is the second fillup since the reflash so I am thinking I can squeeze 18 mpg on this tank !! The new computer flash has a lot of engine protection strategies like turbo vane sweep when your idling, wrench light when the ECT and EOT are out of range,smoother transmission shifts, and smoother cold starts.
Old Mar 7, 2011 | 09:04 PM
Applebutter
fuel mileage
Thanks 8lug for the info, Im going to change the thermostat soon and go get the latest flash update at the dealership also. But im still going to run the AFE filter,just bought it 2 weeks ago. Thanks again.
Old Mar 7, 2011 | 09:13 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Good, then it probably hasn't caused any damage yet. Might as well hear what the experts have to say about it, that's what FTE is best at
Read these and learn about why the factory intake is better:
https://www.ford-trucks.com/forums/5...r-6-0-a-2.html (about AFE specifically)
https://www.ford-trucks.com/forums/5...hy-so-bad.html
https://www.ford-trucks.com/forums/7...endations.html
And here, have some more general info on the 6.0L, common issues, and simple fixes for them.
https://www.ford-trucks.com/forums/8...ir-filter.html
https://www.ford-trucks.com/forums/7...-problems.html
We can't stop you from running the thing, but it seems the best results come from the Donaldson.
"Aftermarket filters for the 6.0 are a waste of time, money, and excess dirt. At no power output levels that 99.5% of the general public will ever see are they needed, warranted, or will do any good whatsoever. We have dynoed plenty of trucks and see NO feasible gain on mild to moderately modified trucks, and in my personal experience I have never gotten a mileage increase from one. Simple matter of fact is that not ONE single aftermarket filter that lives up to the filtering efficiency of the Donaldson. The AFE is efficient; the Donaldson is more efficient. Spend your money and time elsewhere. "
Old Mar 8, 2011 | 01:22 AM
rez runner's Avatar
rez runner
got any tips fer a 7.3 99 f250 4x4 diesel runnin stock i think. this is my first diesel just learnin
Old Mar 11, 2011 | 09:20 PM
Applebutter
Hi 8lug, I went to the ford dealership today(3-11-11) to check to see if i had the latest updates for my truck and they said i did, but i had a code come up for the ficm. They said it is going bad and that could be my problem for poor mpg's. But for them to do it it will cost $1200.00. I have found some websites that they can update the ficm after you send it to them from 225.00-325.00 so i might be checking into that soon.
Old Mar 11, 2011 | 09:26 PM
2006lariat's Avatar
2006lariat
Check Swamps Diesel out, they can sell you an upgraded 48volt ficm for $350, ready to install!
Old Mar 12, 2011 | 10:18 PM
Javo's Avatar
Javo
Go to the 6.0 Tech Folder. There's a link to:
1. Test the FICM yourself
2. Repair the FICM yourself
3. Upgrade your FICM to 58 volts as opposed to 48 volts
My FICM went out about two weeks ago (there's a thread I started), someone pointed me to this fix and it worked perfectly - saved me the $1,200.00!!! Cost me nothing! Next up, I'm doing the 58v upgrade. Don't pay to get your FICM fixed by anybody (Ford dealer or otherwise) until you read that thread - it has worked for many, many people. Let me know if you have questions about it, I just did it.
Good luck.
Old Mar 12, 2011 | 10:25 PM
Javo's Avatar
Javo
Originally Posted by 8lug
...You probably do need a thermostat as my truck was running at 170 degrees and knocked my fuel mileage down to 12 and 13 mpg. I changed the thermostat and now my Scangauge is reading 190+ which is the operating range plus I am able to keep an eye on the engine oil temp which should run no higher then 15 degrees over the coolant temp. These two temp readings need to be monitored so your EGR cooler does not have a melt down . I also got the latest PCM,FICM,TCM computer flash at the dealership and now I am getting 17.5 mpg in my crewcab dually that is up from 14 mpg. I also have the Scangauge set on instant mpg so I can really squeeze more out of each gallon. This is the second fillup since the reflash so I am thinking I can squeeze 18 mpg on this tank !! The new computer flash has a lot of engine protection strategies like turbo vane sweep when your idling, wrench light when the ECT and EOT are out of range,smoother transmission shifts, and smoother cold starts.
I'm getting 10mpg at best in my dually. I would be happy with 14mpg and ecstatic with 17.5!! What temp thermostat did you go to? Why does that affect my mpg?
I'm gonna take my truck by the dealership and have them make sure I have the latest flash. Any other input is GREATLY appreciated.
Thanks.
ligito
Feb 13, 2015 07:37 PM
Stampede
May 9, 2011 01:46 AM
whitetr
16
Aug 31, 2008 11:26 PM
wendal
1983 - 2012 Ranger & B-Series
May 2, 2008 06:30 PM
stevewabc
Feb 21, 2006 09:10 PM
