Problem with starter...shims?
Old Mar 12, 2011 | 05:17 PM
rdfletch's Avatar
rdfletch
Bought a new starter and installed today, along with solenoid & battery. Starter sounds too tight, like it needs a shim, but as I recall, the way they mount this thing, a shim wouldn't do much good. The starter is an Ultima reman unit. Maybe I should try an exchange?
Truck is a 77 F100 300/3spd.
Old Mar 12, 2011 | 06:13 PM
brooklyn's Avatar
brooklyn
right number of teeth for the flexplate?
officially shims don't exist, don't work, and aren't a Ford thing. unofficially they sell them in the HELP! section of most auto parts stores for about five bucks.
Old Mar 13, 2011 | 10:16 AM
rdfletch's Avatar
rdfletch
I got the starter listed for the manual trans, with the power wire connection on the 'back end' of the starter...which is really a tab on the front. The old starter sounded fine. At least as far as engagement goes.
Old Mar 13, 2011 | 11:17 AM
jim collins's Avatar
jim collins
If you still have the old starter ,check to see if the nose of it is the same as the new one. Auto transmission ones will be longer by about 1/4 to 3/8 of an inch. They may have boxed it up wrong and marked it as a standard. NAPA , sells spacer rings you can stack together , I used one for a while until i needed a replacement starter ,then i got the correct one.
Old Mar 13, 2011 | 09:14 PM
rdfletch's Avatar
rdfletch
Yep, already turned in the core. I will probably exchange it, since I bought the one with the lifetime warranty. If that doesn't fix it, I'll pick up a shim.
Old Mar 13, 2011 | 10:39 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Shims? Thats the general crap bowtie stuff. Ford never ever had shims for their starters, ever that I have heard of.
Make sure its the correct flexplate/flywheel. Im guessing its some chinese rebuilt starter contraption.
My 1969 429 rolls over great with the 1994 460 pmgr starter, with some minor wiring upgrades.
Gm and Chev are the only shimmable starters that I know of, poor engineering, figure it out yourself crap.
Egads, Im glad I havent heard that mechanical nightmare sound for along time, of an improperly shimmed bowtie, grinding or whining like nails on a chalkboard...
Old Mar 13, 2011 | 11:40 PM
rdfletch's Avatar
rdfletch
That's exactly what this one sounds like. A grindy whine is the best phrase, just like a GM needing the thicker of the 3 shims. It's an Ultima, bought from O'Reilly's, did not check to see if it was Chinese/Taiwanese, Singapore, Thailand, India, whatever.
Old Mar 14, 2011 | 01:12 AM
Thunderjet4x4
I hate rebuilds. Spent some time on my last rebuilt starter, rebuilding it after I found one of the bendix engagement tangs was broken. By the looks of it, most of the parts were just heavily bead blasted and re-used. It still took 3 starters to make one decent, and with 0 guage custom wires and grounds, was not good. Then I did the starter upgrade, brand new, not rebuilt, with shipping was cheaper than a crappy local rebuild.
I had hot soak slow start, no starts before, and now it just turns over like a smallblock with no plugs in it!
ConklinRacing08
May 5, 2020 01:53 PM
81ChopTop
Apr 23, 2016 06:41 PM
52runner
19
Apr 15, 2016 06:45 PM
SC_Dave
13
Apr 26, 2013 06:39 PM
CaptainIPSC
Oct 28, 2012 08:52 AM
