Van compatibility ?
Old Mar 15, 2003 | 02:24 PM
Ferrite's Avatar
Ferrite
Question Van compatibility ?
I have a question of compatibility of parts between 2 vans.
Donor - 1979 E-250 2wd
Receiver - 1983 E150 2wd
Parts to swap - entire front suspension/steering. Spindles, I-beams,
springs, radius arms, tie rod assembly....all of it.
So my questions revolve around 2 areas;
1) Will '79 parts fit an '83? Since I'd be swapping it all, I'm assuming
I need the frames to be the same. Are they?
2) can I install 250 parts on a 150? Does that then impact the
rear suspension? Do I need both ends from the '79?
Thanks for any help.
-Ferrite
Old Mar 17, 2003 | 11:32 AM
desperado_18_2000's Avatar
desperado_18_2000
Van compatibility ?
If the 250 didn't use leaf springs up front, then you can pull radius arms, drag links and everything and swap them to the 150 van.
You can also swap the rears if you want everything should physically bolt into place.
HTH
Old Mar 17, 2003 | 05:51 PM
steve83's Avatar
steve83
Van compatibility ?
If you don't swap the rear axle, you'll have to carry 2 spare tires since the lug patterns will be different.
BriWas
Jul 8, 2012 02:27 PM
Spool&Go
47
Feb 14, 2012 12:11 AM
Bergerson
66
Sep 29, 2011 12:08 PM
Ferrite
Apr 17, 2004 06:38 PM
Ferrite
May 26, 2002 09:58 AM
