I have a question of compatibility of parts between 2 vans.
Donor - 1979 E-250 2wd
Receiver - 1983 E150 2wd
Parts to swap - entire front suspension/steering. Spindles, I-beams,
springs, radius arms, tie rod assembly....all of it.
So my questions revolve around 2 areas;
1) Will '79 parts fit an '83? Since I'd be swapping it all, I'm assuming
I need the frames to be the same. Are they?
2) can I install 250 parts on a 150? Does that then impact the
rear suspension? Do I need both ends from the '79?
