starters
Old Mar 12, 2011 | 04:18 PM
frenchy107's Avatar
frenchy107
starters
will the starter from my 94 f150 5.0 auto swap into my 89 f150 4.9 manual trans
Old Mar 12, 2011 | 04:33 PM
92nite351's Avatar
92nite351
yes it will, not sure if u need to modify anything but it will work
Big_Al59's Avatar
Big_Al59
I'm not sure but you could look up the part #'s on an auto parts site, like napa. If the numbers are the same......
Or wait for someone who knows for sure.
Old Mar 12, 2011 | 04:38 PM
frenchy107's Avatar
frenchy107
checked part #s already, not a match. hoping someone here knows something
Old Mar 12, 2011 | 04:46 PM
thechief66's Avatar
thechief66
No. Different by year, and different by trans type. You might be able to swap the nosecones, but that's just trial and error.
Old Mar 12, 2011 | 06:13 PM
92nite351's Avatar
92nite351
i put a starter from a 90 i6 on my 351 just had to wire it up to work cuz the 92 and up uses a power wire to the starter instead of the silinoid. so u should be able to reverse the same way...both were automatics....
Old Mar 12, 2011 | 06:54 PM
fordinlinesix's Avatar
fordinlinesix
It'll bolt up no problem, but I believe the tooth count is different between auto and manual tranny's.
davisrn94
13
May 1, 2015 08:33 PM
1992FordF150Custom
13
Nov 6, 2013 06:54 PM
karlhr
1997 - 2003 F150
Feb 8, 2011 04:11 PM
strumgeshutz
Mar 13, 2006 09:17 PM
Shorts
Nov 19, 2003 10:26 PM
