Code 213 SPOUT Circuit Open
Old Apr 8, 2012 | 01:36 PM
  #46
jeep802001's Avatar
jeep802001
You have to disconnect the spout to set timing right?
Old Apr 8, 2012 | 03:12 PM
  #47
rla2005's Avatar
rla2005
Correct.
Fuel Injection Technical Library » Setting the timing
Old Jan 26, 2013 | 08:40 AM
  #48
bbciradio's Avatar
bbciradio
Solution?
Originally Posted by bobrpm306
No, it's still not fixed yet. I've been pretty busy and haven't worked on this problem in a while. The only update I have is that the timing isn't retarding for that split second, it's advancing. I was looking at that wrong. Everything seems to check out and it points to the computer being the problem. I'm reluctant to spend a bunch of money replacing the computer since that junkyard unit shows the same problem with the same symptoms as the original. I'm weighing whether to spend $250 on a reman computer or just spend the money on an old carb intake and distributor and be done with it. The timing seems to be doing what it's supposed to be doing--advancing when it should--except for those quick misfires. Also, it only seems to be advancing to about 26* total. That seems low to me, but this is my first six cylinder.
Hi Bob, what ever was the solution to your problem? I have went through the 213 checks, and am pointed to section 8a distributor/ignition diagnosing. So, I seem to have a similar problem to what you have had. Thank you much!!
Old Feb 9, 2013 | 10:18 PM
  #49
bbciradio's Avatar
bbciradio
Please help if you can.
Moved question.. thx https://www.ford-trucks.com/forums/1...ease-help.html
tempest411
24
Jun 5, 2025 11:11 PM
renob
20
Sep 27, 2019 06:49 PM
kjs5055
Nov 10, 2016 05:51 PM
efrntzl
Sep 19, 2015 10:12 PM
ForOffRoadDriving
May 25, 2007 06:19 PM
