Lowering Kit Results
Old Mar 12, 2011 | 11:42 AM
ibileaux's Avatar
ibileaux
New to the F150 scene.
Bought a '93 Flare-side. One of the first things is to improve suspension and to lower it. Will the Lightning suspension parts fit on my '93? Will call Summit tech support Monday about their lowering kits. Any additional info or experience with suspension will be greatly appreciated.
Old Mar 12, 2011 | 12:09 PM
96f350az's Avatar
96f350az
why not axel flip?
Old Mar 12, 2011 | 12:59 PM
Jason Lewis's Avatar
Jason Lewis
Yes lightning parts will fit, springs ! front and rear
Old Mar 12, 2011 | 02:00 PM
86F150302's Avatar
86F150302
I think you should go ahead and do the 3/4 or 3/5 though.
Old Mar 12, 2011 | 10:02 PM
ibileaux's Avatar
ibileaux
Thanks for all the help. I have built Mustangs, so some of the f150 terminology is new to me. Like axle flip. Please explain.
Thanks for letting me know Lightning parts can be exchanged with the 150.
I was looking at Summit's suspension kits. The DJM KS3000-3-5 Kit. It lowers the front by 3" and rear by 5". The Beltech Sport Trucks Lowering Kit 921ND.
The Belltech is $730 (about 130 more then the DJM kit) but looks stronger. Even has replacement springs. Calling Summit tech support to find out if either fits my 150.
But anyway, thanks for all the info....Gaye'
Old Mar 12, 2011 | 10:47 PM
Ed Bamba's Avatar
Ed Bamba
An axle flip is when you take the rear axle from the bottom of the leaf springs and place it on top of the leaf springs. The components for the rear flip is called a "flip kit". The kit usually consist of two u-shaped brackets that are placed under the spring perches and are the new spring perches at the bottom of the axle. The brackets also place the axle at the correct angle with respect to the drive shaft.
The flip kit is designed to provide a 5" drop, whereas the drop shackle and front spring hangar combo only provides a 4" drop. Some owners have commented that a frame notch (C-Notch) is required if you go with the flip kit, just check with the kit manufacturer if they recommend or require the use of a c-notch for a 5" drop.
Can't comment on which of the two kits are best. Hopefully someone who has compared the two will respond.
Ed
Last edited by Ed Bamba; Mar 13, 2011 at 08:03 AM. Reason: Made correction to kit component application
Old Mar 13, 2011 | 12:53 AM
SideWinder4.9l's Avatar
SideWinder4.9l
I purchased the 2" lowering shackles...And lovem'....
-Wes
Old Mar 13, 2011 | 12:51 PM
86F150302's Avatar
86F150302
I had the DJM 3/5 and it was great. Whenever I lower my Lightning I will go with DJM again. Not that Beltech isnt good I just don't like their prices.
The Beltech kit you posted is a 2/3 drop. It has drop springs.
The DJM kit is 3/5. It has new drop I beams for the front. You will need a C notch with the flip kit though. I didn't have one on my old truck for a while and you only have like 1" before the axle hits the frame without the notch.
Old Jun 27, 2011 | 03:17 PM
jborushko's Avatar
jborushko
stupid question... but do those kits work on 4x4 or 2wd only? i was looking at DJM3000-3/4. i have a 93 flareside 4x4 im getting ready to race out (and keep my 4wd)
i know this is the a dumb question but i cant seem to find anybody that mentioned they did it on a 4x4. also i would like to see the installation instructions
thanks
-sorry for the hi-jack, this q doesn't warrent a new thread
Old Jun 27, 2011 | 03:29 PM
strokin'_tatsch's Avatar
strokin'_tatsch
To my knowledge there is no real way to lower the front of 4x4 with a TTB under it. You could put the 2" lowering shackles on a 4x4 to lower the rear end to match the front though. You could cut the stock springs down to lower the front end if you wanted to, but what that would do to alignment, I don't know... Probably mess it all up since it's a TTB
Old Jun 27, 2011 | 03:49 PM
jborushko's Avatar
jborushko
yeah... i just got a reponce back from djm they said "no". i assume i could use somekinda camber kit?? well to the internet! i guess i will start a thread now then.
Old Jun 27, 2011 | 08:16 PM
Slowroll90's Avatar
Slowroll90
I got djm 2" drop shackles and only got about 1" actually reduction in ride height
Old Jul 11, 2011 | 02:05 AM
jborushko's Avatar
jborushko
what did you do about the front? or are you 2wd?
Old Jul 11, 2011 | 02:59 AM
TexasGuy001's Avatar
TexasGuy001
I have to ask, why lower a 4x4?
Old Jul 11, 2011 | 03:11 AM
SideWinder4.9l
x2..........
