I/C leak
Old Mar 12, 2011 | 09:20 AM
timmyboy76's Avatar
timmyboy76
I/C leak
Is it possible to have a leak, from inside where the cooling fins are, or more proned to where the boots connect to/outlet necks?
Old Mar 12, 2011 | 09:39 AM
mueckster's Avatar
mueckster
Most of the time, you see leaks at the boot connections. I did have a 6.0 I/C that had a small crack in the plastic tank. Unless the core is physically damaged, it is rare to see a leak in the tubes or headers (ends that the tanks attach to).
Old Mar 12, 2011 | 09:45 AM
timmyboy76's Avatar
timmyboy76
cool...just didnt want to throw my money away, chasing a leak/s. I guess i can fill it up with water, and have a gander at it.
Old Mar 12, 2011 | 10:01 AM
Larry_the_handyman's Avatar
Larry_the_handyman
If you have a stock I/C it's quite possible that the plastic to metal connection is leaking or the plastic end tanks have a crack. On mine, I had a boot blasting air/oil onto the valve cover and it was clear where it was coming from.
johnstonmatt77
Sep 2, 2014 12:54 PM
chuck7300
Jul 18, 2014 05:07 AM
Windsetter
Aerostar
18
Nov 21, 2010 03:29 PM
Navdriver
13
Apr 19, 2007 02:20 PM
Ford Blue
1966 - 1977 Early Broncos
Jan 24, 2005 12:48 AM
