X spring ###'s
Old Mar 11, 2011 | 09:54 PM
muddman77's Avatar
muddman77
X spring ###'s
Tryn to track down a set of X code springs. Found a guy thats got 25 sets of springs, I need to know all possible codes for X springs. Also a friend has a truck with springs that have the code F81AAED on them, he says that they are x code, but I cant find that code on any of the spring lists I found using the search tab. His truck has UA on the door sticker, could they have been changed at the dealer? He bought the truck new. All these codes have me stumped, and I wanna make sure I get the right springs.
Old Mar 12, 2011 | 07:15 AM
muddman77's Avatar
muddman77
nobody knows
Old Mar 12, 2011 | 07:32 AM
timmyboy76's Avatar
timmyboy76
Haven't got a clue bud, but if anything, i'd look at the dif'rent springs, and atleast count how many, are on yours, then match'em up.
Old Mar 12, 2011 | 07:48 AM
jwhitetail's Avatar
jwhitetail
IF it's a X code its stamped on the main leaf were it wraps on the eye, I sold mine. there on F350's if that helps.
Old Mar 12, 2011 | 08:39 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I changed my springs to X code last year, but I don't remember the #'s.
Why are you changing them?
Old Mar 12, 2011 | 01:03 PM
muddman77's Avatar
muddman77
I'm chasing a handling crappy problem. I've replaced every part of the front of my truck tryn to make it drive better, even a red head box, still wonders all over the road. My wife wont drive it and it freaks me out every now & then.Its been to three shops and they all say its fine and within spec. The only thing left are springs, and I've read X codes will give the truck more stability and i need all that I can get..
Old Mar 14, 2011 | 08:19 AM
miller_feed
Have you thought maybe the tires are causing this?
Old Mar 14, 2011 | 08:46 AM
wolfman08's Avatar
wolfman08
There are multiple part numbers for the X codes depending on the year they were manufactured IIRC. The easiest way is to verify from the spring code from the truck they were removed from.
The aftermarket and/or SRI part number for the x-code springs are 43-818.
Old Mar 14, 2011 | 08:56 AM
Mitch1407's Avatar
Mitch1407
my dad has the same problem. Its definitely the tires because he had a nice road tire on there then switched to a BFG A/t and its too narrow for the weight..
Find a buddy with the same truck that will let you borrow his rims n tires for a week.
IDI-Charlie
Oct 1, 2016 07:55 AM
Footy
May 26, 2012 06:58 AM
SuperDutyScaler
Jan 25, 2011 11:47 AM
greenwoodford
Jul 8, 2010 10:10 PM
grmnrkt
Jan 19, 2009 07:11 AM
