Bronco II Ford Bronco II
blinker problem
Old Mar 15, 2003 | 12:14 PM
baddmove's Avatar
baddmove
blinker problem
o.k. all..check this out!!! i bought by bII a month ago and have went through 18 fuses so far..the blinkers will stay on for a day or 2 then blow a fuse....i have chased every wire down and cannot find a problem with them...i took the steering column aprt, put in a new starter module and nothing i have done will keep the blinkers on..sometimes the fuses will blow right when i turn the key on and some times it will blow when rolling down the street...go figure...anyone have this blinker problem or any ideas? thanx!!
Old Mar 16, 2003 | 12:30 PM
junkyarddog86's Avatar
junkyarddog86
Question blinker problem
Please check your light sockets to make sure it does not have a broken or damage insulator, it could be shorting to ground there. Good luck
simper82
Jan 15, 2014 10:56 PM
PARanger98
1983 - 2012 Ranger & B-Series
Nov 18, 2010 03:08 PM
Rizon
Sep 24, 2007 09:55 PM
rush2112
Nov 30, 2006 05:49 PM
