Bronco II Ford Bronco II
rear wheeling bearings
Old Mar 15, 2003 | 05:47 PM
bigblockbronco's Avatar
bigblockbronco
Question rear wheeling bearings
has anyone ever replaced rear wheel bearings in a 1989 bronco 2 ?
Old Mar 16, 2003 | 09:58 AM
mrshorty's Avatar
mrshorty
I've done it on my explorer (8.8 axle which is just a bigger version of the 7.5 axle on the BII). It's not a difficult job. A little time consuming because you have to open the differential in order to remove the axles. The hardest part of the job was finding the proper bearing puller (T-shaped foot that fits on a slide hammer) to get the axle bearing out.
You may also find a broken pinion shaft lock bolt in the differential. That comes out real easy with the proper bolt extractor. Skyway tools has a short write up and sells a kit for extracting these bolts, if you're interested in looking it up.
One last thing, if you don't already have a Chilton's ,Haynes, or other manual, I'd get one. The basic procedure is fairly well outlined there.
Old Mar 16, 2003 | 01:39 PM
bigblockbronco
thanks, i did not know about the t shaped puller i will need for my slide hammer
