door seals
Old Mar 18, 2011 | 08:17 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Originally Posted by McGiver
I'm surprised no one mentioned Softseal.com. They have hollow rubber seals and your door will close fine the first time. I had some stock rubber ones and ended up peeling those new ones off and throwing them away.
Are they available for Bonus Built trucks? What year is your truck?
Old Mar 19, 2011 | 09:31 AM
McGiver's Avatar
McGiver
I have a 51 F-1 on the road with a 239, 3 on the tree, a 50 in progress with a 224 and another 49 or 50 totally disassembled. I dont think softseal makes kits specifically for the truck, I just got strips to go around the doors where the stock rubber was too tight.
That may lead to another problem I have. Even though the doors close tight, Ive noticed they rattle and move slightly when going down the road. The hinges and pins are tight but not perfect. There is a slight movement of the door and the cab surely flexes too. I wonder if anyone has solved this problem with bear claw latches.
Old Apr 18, 2011 | 03:06 AM
iwanaflattie's Avatar
iwanaflattie
Hey McGiver.
I have the same problem with my driver side door.The whole door bounces up and down and it makes this rubbing deep noise,so I looked at my hinges and they were tight but the top hinge (where the pin is)was loose.
The PO had replaced the stock pin with a bolt so there was play on it.
I just put a slightly bigger bolt on it tonight that fit tight(i didnt force it),no more play.
I will let you know if that fixed the problem.
If your pin holes are stretched I am sure you can either put a sleeve in or redrill the hole and put a bigger bolt like I did.
Do you know the part number for the door seals????
I went to their site and did a search and it came back with no results.
Thank you
Seth
Old Apr 18, 2011 | 06:20 AM
fergusonicford's Avatar
fergusonicford
I had ordered hallow door seal from Mid-fifty last December.....they got Back ordered......and to date their vendor has not supplied them with any and they don't know when he will. Sac Vin Ford: same thing. I wound up just getting the regular solid ones.
Old Apr 18, 2011 | 11:33 AM
raerjim's Avatar
raerjim
I bought new D Carpenter seals. They were fine but I replaced them with the Mid Fifty hollow seals, which are terrific.
Old Apr 18, 2011 | 06:44 PM
carnut122's Avatar
carnut122
So skip the solid seals and go for the hollow seals?
Old Apr 18, 2011 | 06:57 PM
sdetweil's Avatar
sdetweil
the hollow seals are fabulous!..
I put them on my 55 last summer.. amazing.
seems there is a problem getting the ones for the 56's now..
sam
Old Apr 18, 2011 | 08:59 PM
Mervy49's Avatar
Mervy49
When I used to build kit cars in the 80's I used the hollow version seals on all the cars, I could get it in rolls un precut. I wonder if it is still available in that form today? If I remember I think it came in 16 foot rolls. You just installed it and then trimmed off what you didn't need. Never had a problem with it not fitting. I can't remember the name of the supplier.
Old Apr 18, 2011 | 09:12 PM
sdetweil's Avatar
sdetweil
These are custom formed at the bottom of the doors.
Sam
Old Apr 18, 2011 | 11:04 PM
arrowheadfred's Avatar
arrowheadfred
AIR TIGHT
I have had to seals on for a while and they work good now SO GOOD that i have to crack the window to get the door to shut . I must have did something right. LOL
Old Apr 19, 2011 | 08:00 PM
McGiver's Avatar
McGiver
I looked for a part number but couldn't find the old receipt. I agree, the help at soft seal is not helpful. I found a small piece in the garage. It is foam rubber, has a 1/2" wide flat with a self adhesive orange peel off tape, the height is 1/2" and round, the hollow area is round about 3/16".
Old Apr 19, 2011 | 08:17 PM
arrowheadfred
paint supply
Check with your local auto paint supply store for the hollow seals. The one in panama city fl. has all kinds of auto stuff. I got the clips that hold the chrome on the hood there and i saw all kinds of auto stuff.
Old Apr 20, 2011 | 05:43 AM
  #28
hellfirejim's Avatar
hellfirejim
On my 50 I need door seals as mine are hard and breaking apart. It appears that hollow seals are the best but who do I get them from if they are avaiable? if they are not available where do I get the seals that go around my doors?
thanks
jim
Old Apr 20, 2011 | 05:53 AM
  #29
iwanaflattie
I bought some hollowed seals from autozombies but it was too thick and the top of my driver side door wont shut all the way.
Old Apr 20, 2011 | 07:24 AM
  #30
arrowheadfred
seals
thanks
jim
check with classic haulers
