Bronco II Ford Bronco II
My BII
Old Mar 14, 2011 | 02:41 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
O-goodness...I am learning a ton
Old Mar 15, 2011 | 07:34 AM
IB Tim's Avatar
IB Tim
So is this what I should do
Originally Posted by Clint1973
the box under the carpet on the pass side floorboard is the inertia switch, (crash switch) fuel shut off. The emmision reset switch on mine is under dash, pass side. open the glovebox, push in sides so it falls all the way down, straight up underneath, if key buzzer works, right next to it. Think i used a little screwdriver, or allen wrench or something
Old Mar 15, 2011 | 09:34 AM
tommyleea's Avatar
tommyleea
Try disconnecting your battery cables, and touching them together. This works for the OBDII systems, not sure if it will work for OBDI, but worth a try. Cheers.
TommyJ
Old Mar 15, 2011 | 08:44 PM
ctubutis's Avatar
ctubutis
As was posted earlier, the Emissions light isn't connected to the computer.
IMHO the best thing to do is find that little box (apparently accessible through the glove
compartment) and reset the thing, I'd imagine the resetting would have to be done with the
ignition ON.
Old Mar 19, 2011 | 07:40 PM
IB Tim's Avatar
IB Tim
OK me try that.....
spiritwild
Bronco II
Aug 1, 2015 06:48 AM
Shanook9080
Bronco II
May 19, 2014 02:46 PM
jecsd1
Bronco II
Apr 4, 2014 05:36 PM
22fordguy
Bronco II
Jul 20, 2013 03:56 AM
SunDog247
Bronco II
Jul 4, 2013 10:39 PM
