Bronco II Ford Bronco II
New member
Old Mar 14, 2011 | 10:37 PM
89broncoll's Avatar
89broncoll
New member
Hey all just bought an 89 b2 was wondering was the first thing I should to to make it better offroad?
Old Mar 15, 2011 | 11:06 AM
im2tall33's Avatar
im2tall33
welcome to fte!!! well first of all bIIs are amazing off roaders the way they are imo...but i would start with some good tires like cooper st tires...there are lots of other things you can do but it all depends on buget and such and what type of wheeling you want to do
Old Mar 15, 2011 | 09:57 PM
89broncoll's Avatar
89broncoll
Its got a small lift and 32 inch kumho road ventures.I mainly will be using it for daily road use and light weekend wheeling.
Old Mar 16, 2011 | 12:38 PM
89broncoll's Avatar
89broncoll
I was wondering what I should cover or avoid spraying in the engine bay?I want to spray it off with sOme engine degreaser
Old Mar 16, 2011 | 01:01 PM
im2tall33's Avatar
im2tall33
cover the battery and the distibutor for sure i think you will be fine after that
Old Mar 16, 2011 | 02:26 PM
89broncoll's Avatar
89broncoll
Ok.yeah it's all mud covered tryin to clean it up a bit to look for a small oil leak. I was also wondering should I change all the differential fluids and man. Trans. Or just leave them?will it hurt to do drain and fills
Old Mar 16, 2011 | 02:59 PM
im2tall33's Avatar
im2tall33
that i dont know for sure.. but it is always good to change your fluids..
Old Mar 16, 2011 | 03:02 PM
89broncoll's Avatar
89broncoll
Yeah I know that the trans seems to kind of grind a gear or two I don't know if the clutch isn't fully engaging or if the fluid is worn out and not really doin anything
Old Mar 20, 2011 | 04:06 AM
mdr617's Avatar
mdr617
yeah could be some really old fluid in the tranny...from my experiance, i think prolly 80% of people never change or check the fluid in a manuall trans. Good luck with the bronco II
Old Mar 20, 2011 | 12:44 PM
89broncoll's Avatar
89broncoll
Yeah.I worked at a lube shop and am pretty knowledgable about vehicles.I just dnt want to replace it and have bigger issues
Old Mar 20, 2011 | 08:35 PM
mdr617's Avatar
mdr617
what do you mean have bigger issues?
Old Mar 20, 2011 | 10:39 PM
89broncoll's Avatar
89broncoll
Well I've always personally been leery about changing trans. Fluids. I'm just afraid for some reason id replace it and the trans. Would act up
Old Mar 21, 2011 | 07:27 PM
mdr617's Avatar
mdr617
right..i have heard of that but on much older vehicals...like some gunk was acting like a seal, but when the gunk was drained out, opps...there goes the seal...
