Violent Vehicle Shutter
Old Mar 11, 2011 | 07:24 AM
yukgoon's Avatar
yukgoon
So I have a 82 F100 with an 300 inline 6. I installed a holley 4187 4 bbl and dual exhaust. I rebuilt the transmission in 08 and installed a new clutch in 07. My issue is that occassionally in reverse the vehicle will violently shutter when i start out. i have to gently release the clutch and it will begin to shutter and shake the entire truck. I have not been able to figure out what causes this. I put 31 inch BFG ATFs on the truck but have the original differental in. Could this be a gearing issue and if so can you recommend a new differental that I should put in. I do off road in the truck but always have to be aware of where I go. Of course it is only a 2 wheel drive. Not looking to do any hard core stuff but would like to maybe step up the rear end.
Old Mar 11, 2011 | 07:45 AM
spurredon's Avatar
spurredon
Are your U-bolts good and tight?
Old Mar 11, 2011 | 12:35 PM
Rogue_Wulff's Avatar
Rogue_Wulff
When you replaced the clutch, did you have the flywheel resurfaced?
What about engine/trans mounts? If they are in need of replacement, they won't the the engine/trans as solid as they should.
I'm guessing you have either a 3 speed or the 4 speed w/OD, as the granny 4 has such a low geared reverse that you shouldn't need to "slip" the clutch to get moving.
ap24
Nov 21, 2013 12:24 PM
Chassisman
Sep 27, 2013 08:08 AM
dines78
Dec 10, 2012 07:35 AM
jimmythetoolman
1997 - 2003 F150
15
Dec 8, 2004 03:18 PM
jgibson3
1997 - 2003 F150
Nov 30, 2004 12:24 AM
