Max tow question
Old Mar 10, 2011 | 08:23 PM
driller tom's Avatar
driller tom
Question Max tow question
Im trying to figure out if my 07 has the max tow package, How can you tell?!?
Old Mar 10, 2011 | 10:25 PM
1bad67sbf's Avatar
1bad67sbf
i think your talking about the f150hd and they are rare and have 7 lug wheels.
Old Mar 10, 2011 | 10:34 PM
snowdog79's Avatar
snowdog79
There really wasn't a "max tow" package in '07. The factory tow package consisted of the 2" receiver, 7-way trailer wiring and oil cooler. The tow rating is based on the cab size/rear axle ratio/engine combo. The heavy duty package (regular or supercab, 8' bed, 7 lug wheels/4.11 axle) tows the most, all the other 5.4 powered trucks fall into a reasonably narrow range. Do you have the factory installed hitch and 7 way trailer wiring? Your owners manual will tell you what your tow rating is, you will have to know your axle ratio.
Old Mar 11, 2011 | 11:44 AM
MCDavis's Avatar
MCDavis
His 6.5' bed should give away that he does not have the heavier running gear and 7-lugs, which is referred to on the spec sheet as the "5.4L payload package".
Link:
https://www.ford-trucks.com/specs/20...rd_f150_1.html
Old Mar 11, 2011 | 10:40 PM
driller tom
Thanks for clearing it up for me fellas!! I have the hitch and wiring.. Im looking at putting a gooseneck hitch in my truck to haul around some scrap steel would it be wise to install some helper springs or airbags?
Old Mar 12, 2011 | 06:44 AM
MCDavis's Avatar
MCDavis
Yeah Tom I do think that'd be a good idea. The thing about a gooseneck though is the pin weight. Remember that if you're exceeding the posted load capacities of your truck while on a public highway that you could get yourself into some trouble with the law. The 150 really isn't meant to take 5th wheels, but it can. That's where the 250 and 350 really shine.
But, add-a-leaf or air bags would be a smart move. How much does the trailer weigh by itself?
Old Mar 12, 2011 | 07:53 AM
1bad67sbf's Avatar
1bad67sbf
air bags are > than add a leaf because add a leaf will ride rough all the time without a load and it will lift the rear of you truck so without a level kit in the front it will look goofy but you can let the air out of the bags some and get the factory ride quality and height back.
Old Mar 12, 2011 | 12:54 PM
Greg B's Avatar
Greg B
I added an Add-A-Leaf and set it to the max load capacity and can't tell much difference in ride quality. My 06 always rode a little rougher than my SD did. It was probalby due to the extra foot in wheelbase and much taller sidewalls in the tires. It works great for the 7 or 8 times a year I tow. If I were to tow everyday, I would have a SD instead of an F150.
Soko179
2015 - 2020 F150
Mar 20, 2015 10:54 PM
drh1175
2009 - 2014 F150
19
Feb 12, 2011 05:22 PM
dontrowell
2009 - 2014 F150
30
Mar 11, 2010 04:58 PM
cecilt
Dec 10, 2009 04:01 PM
seth1
All Things Towing
Jul 23, 2005 10:41 PM
