Yea i know its a Ford forum BUT it is atleast 4x4 lol
Anyways i just picked up a 87 Jeep wagoneer limited 4x4 with the 4.0 in it itll run all day long at idle and up to 2000 ish (no tach in it) after that it looses power my guess is its a clogged fuel filter or the fuel pump isnt keeping up with it the plugs need changing and the distributer could use a cap prolly or cleaned any other ideas on it?
i miss my old cherokee. 315,xxx and would still light em up with ease
check the exhaust too if you can fit your round self under it :flipoff:
it sounds like not enough fuel or spark, but maybe theres a pinched exhaust pipe. any overheating issues when you try to run it at higher rpms? ditch the cat if it has one.
Its got a exhaust leak and as loud as it is theys no way its pinched although the cats gonna go bye bye
