1994 F-150 Fuse U
1994 F-150 Fuse U
I have a 1994 F-150 4.9L
It has started popping fuse U That is the TFI Ignition Module, Ignition Coil, Distributor, and EEC power relay fuse. It is sporadic. Will go a few hours to a few days. I have noticed the volt gauge on the dash will drop suddenly a few times before the fuse pops. So I'm fairly sure it is a short. I guess I'm asking for a common area this happen in? Or has someone experienced the same problem?
Thanks,
Jeff
Thanks,
Jeff
