Need help finding the right fuel pump.
Old Mar 8, 2011 | 07:33 PM
frog1377's Avatar
frog1377
I have a 1986 F250 extended cab,4x4 with duallys. It has a 460 with a holly carb in it, I am not sure that the previous owner took a 350 frame and put the 250 body on it, but any ways. I have bought a new rear steel tank it is Dorman Fuel Tank 576-119 19 gal. I cannot find the right fuel pump assembly for it and am very frustrated after buying one for the side tank. Does anyone know the correct fuel pump that I need? The only one I can find is for a poly tank on a 7.5l.
Old Mar 8, 2011 | 07:53 PM
ctubutis's Avatar
ctubutis
Is this an in-tank pump?
Old Mar 8, 2011 | 07:56 PM
frog1377's Avatar
frog1377
yes, the old one had a tag on it but the only thing I can make out is 9H307
Old Mar 8, 2011 | 08:57 PM
ctubutis's Avatar
ctubutis
E5TZ-9H307-F superseded by E5TZ-9H307-FA SENDER & PUMP ASY
Fits 85/86 F250/F350 V8 460 w/aft steel tank
Obsolete
MSRP $231.99
One of our sponsors Ed Olson www.partsguyed.com sells it for $186.52
(Ed recently had a stroke; even though he won't be returning to work until next month,
his co-workers are answering Web orders in their spare time. This is a Ford dealership (I
think Horizon Ford in Seattle, WA) so please be patient with them if you choose to buy
there and they seem slow.)
<hr>
<dt>Green SalesCo</dt> <dd>CINCINNATI, OH 45237</dd> <dd>Dealer Website</dd>
1-800-543-4959
Has Qty. 4
<hr>
<dt>Bob Allen Ford</dt> <dd>9239 Metcalf Avenue,</dd><dd> Overland Park, KS 66212<dd>(913) 381-3000<dd>Dealer Website</dd>
Has Qty. 5
<hr>
<dt>Nelson Ford Kia</dt> <dd>4730 Virginia Ave; Bassett, VA 24055<dd>Collinsville, VA 24078</dd><dd>(877) 217-4205</dd><dd>
Has Qty 1
<hr>
<dt>Tison Motor Company Inc.</dt> <dd>710 East Railroad Avenue<dd>Estill, SC 29918<dd>(888) 351-7488 </dd>
Has Qty. 1
<hr>
<dt>Parts International Farmersbranch Ford</dt> <dd>FARMERS BRANCH, TX 75234</dd> <dd>888-727-0418</dd><dd>Dealer Website</dd>
Has Qty 14
<hr>
Because the part number was superseded, different sellers have it listed under different part numbers.
The only place listing it under the E5TZ-9H307-FA new number is Nelson Ford Kia in Virgina.
All the other places reference it as the old number, E5TZ-9H307-F
Old Mar 8, 2011 | 09:47 PM
frog1377's Avatar
frog1377
Thank you gonna check it out.
Old Mar 8, 2011 | 09:50 PM
frog1377's Avatar
frog1377
is the dash F, FA the same as dash B?
Old Mar 8, 2011 | 10:00 PM
ctubutis's Avatar
ctubutis
The parts catalog says E5TZ-9H307-B (superseded with E5TZ-9H307-BA) is for an
85/86 F150/F250 V8 302 EFI w/aft steel tank.
Old Mar 8, 2011 | 10:01 PM
frog1377's Avatar
frog1377
K so the f is for the 460, got ya, thanks again.
Old Mar 8, 2011 | 10:04 PM
ctubutis's Avatar
ctubutis
The computer says Tison Motor Co in SC has both F and BA, you might want to call them
if you wanna know the differences.
Old Mar 8, 2011 | 10:16 PM
ctubutis's Avatar
ctubutis
Actually, I can tell you the differences... the EFI pump will pump at a higher pressure (that
system runs on around 37 psi IIRC whereas carbs use 4-7 psi).
Old Mar 8, 2011 | 10:18 PM
frog1377's Avatar
frog1377
so I would probably blow seals if I used the b.
nova801428
Dec 28, 2016 11:25 AM
Motosk813
Jan 16, 2016 09:34 PM
Ex-ChevyOwner
Oct 7, 2015 09:14 PM
rustranger
May 22, 2014 10:56 AM
Jeffery the first
Mar 8, 2011 05:30 AM
