Emissions puzzle
Old Mar 8, 2011 | 11:07 PM
spongecop's Avatar
spongecop
Semper Fi
Emissions puzzle
Have a 82 f150 300/6 with 1 bbl Carter yf. Emissions system is a disaster and I am missing the label on the radiator cowl. Can someone tell me on the vacuum tree coming off thermostat housing which terminal goes where. Mine is green with four vacuum ports labeled by letters. Thanks.
Old Mar 9, 2011 | 10:55 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Can you post the letters on the Ported Vacuum Switch (PVS), and what nipple each letter coresponds to on the (PVS).
Without the emissions lable, it's going to be hard to tell how that PVS is routed and for what.
Does your carb still have the original motorcraft carb tag? If so post the numbers. That might help narrow your calibration code.
Old Mar 9, 2011 | 11:07 AM
Franklin2's Avatar
Franklin2
AutoZone.com Repair Guide Image
Here's a diagram, it's not your exact year but it does have the 4 port valve in it, and it is a six.
Old Mar 9, 2011 | 11:08 AM
Franklin2's Avatar
Franklin2
