302 heads
Old Mar 21, 2011 | 09:41 PM
Conanski's Avatar
Conanski
Yes the intake will fit, all SBF heads are the same spec with regards to the intake location and spacing.
Old Mar 23, 2011 | 07:32 PM
1stTruck's Avatar
1stTruck
Conanski, what are E7T heads? i did a search but couldnt find what year and vehicle the heads come off.
Old Mar 23, 2011 | 09:00 PM
strokin'_tatsch's Avatar
strokin'_tatsch
E7's are the stock heads your truck should have. I think Mustang GTs also had the E7's along with non lightning trucks with the 351w. Pretty sure that's right.
Old Mar 23, 2011 | 09:06 PM
1stTruck's Avatar
1stTruck
could this E7T heads come of a 1992 to 1995 ford lightning? the GT40 heads that i bough were not pollution heads. there is a set that i am looking. the guy say its off a ford lightning. he said there 351W and gave me the casting Number E7T.
my questin is are these heads better than the 302 on my 93 f150? and which head would be better the GT40 or the 351W?
Old Mar 23, 2011 | 09:51 PM
strokin'_tatsch
The E7 from a 302 and the E7 from a 351 would be the same heads.. You should already have these heads on your truck. The GT40s came stock on the Lightning. If he is finding E7s on a Lightning, someone probably put those heads on after messing up the GT40s. Go with GT40 heads or GT40P heads if you can. With GT40P's you will have to find headers that are designed to fit them, but they are out there. GT40s are easier to mess with though b/c you can use headers designed for your truck.
Old Mar 23, 2011 | 09:55 PM
Conanski's Avatar
Conanski
Originally Posted by 1stTruck
could this E7T heads come of a 1992 to 1995 ford lightning? ?
NO, somebody is trying to scam you.
Again... what are the casting numbers off these heads? You will find the casting number on the head gasket side near one of the center intake ports, get this info and post it up.
Old Mar 23, 2011 | 09:57 PM
strokin'_tatsch
Agreed.. You need to go look at these heads yourself, not let somebody else tell you what they are.
Old Mar 23, 2011 | 10:25 PM
1stTruck's Avatar
1stTruck
i dont have the GT40 heads. i got a refun on them but when i looked at the heads i seen the GT and i believe F3ZEAA on the casting
so the heads that i been looking at supposedly are from a 351 windsor of a lightning. the shop said this heads will flow better than the 302 heads
are the heads from a 351w and 302 the same? or do the 351w flow better?
Old Mar 23, 2011 | 11:22 PM
strokin'_tatsch
The heads E7 heads between the 302 and 351 are the same heads. Flow the same... The GT40s between the 302 and 351 are also the same and flow the same.
Old Mar 24, 2011 | 05:19 AM
1stTruck's Avatar
1stTruck
i was thinking the 351 had bigger valves than the 302. wouldnt bigger valves make make more HP/TQ?
Old Mar 24, 2011 | 07:29 PM
1stTruck's Avatar
1stTruck
got more info. I couldnt understand the shop over the phone plus the guy has a heavy accent.
ok so the heads are 351 close chamber. those these rings a bell to anyone?
Thanks
Old Mar 24, 2011 | 08:33 PM
strokin'_tatsch
Need a CASTING NUMBER.. GT40? E7TE? something else???
Old Mar 24, 2011 | 08:38 PM
  #28
503racing's Avatar
503racing
if he is telling you he is putting e7 heads on my advice is get your truck out of that shop. he will prolly clean yours and say theyre new. E7 are The same 302 0r 351 the only difference is the bolt diameter on the head bolts, thats it. seriously by the sounds your being scammed.
Old Mar 24, 2011 | 09:10 PM
  #29
Conanski's Avatar
Conanski
i dont have the GT40 heads. i got a refund on them but when i looked at the heads i seen the GT and i believe F3ZEAA on the casting
Those are real GT40 heads and they're better than E7TEs. Why did you take them back?
Old Mar 24, 2011 | 09:18 PM
  #30
Conanski's Avatar
Conanski
Well if they are E7TE castings they are NOT from a Lightning.. I don't care what your guy says, and they won't flow any better than a set from a 302.
Yes they are IDENTICAL except for the bolt hole size. You have to get GT40 heads(like you had) to get better flow and it doesn't matter if they come off a 302 or 351 they will both work on your motor.
