TPS senors
Old Mar 8, 2011 | 05:10 PM
rboyse's Avatar
rboyse
TPS senors
what wont my TPS senors stay were i set it at?
Old Mar 8, 2011 | 05:15 PM
dgoertel's Avatar
dgoertel
Un plug it. it should idle around 750 then. If does you probly need a new sensor. Im guessin it idles around 1500 right now
Old Mar 8, 2011 | 05:41 PM
rboyse's Avatar
rboyse
idle around 650 my other iss is that am getting to much volts to the tps mine is 7 sopp to be no more than 5
Old Mar 8, 2011 | 06:05 PM
subford's Avatar
subford
What are you using for ground when you get that reading?
You need to be using SigGnd or RTN on the same plug.
If you are getting that voltage replace the Computer, the 5 volt supply is bad in that computer.
Old Mar 9, 2011 | 05:48 PM
rboyse's Avatar
rboyse
we went and got a new tcm and same thing voltage over 7
Old Mar 9, 2011 | 06:02 PM
subford's Avatar
subford
What is a "tcm"??
Old Mar 9, 2011 | 08:25 PM
rboyse's Avatar
rboyse
transmission control modgule or (aka) computer
Old Mar 9, 2011 | 09:08 PM
subford's Avatar
subford
I take it that we are working on a Diesel then.
Old Mar 10, 2011 | 01:09 PM
rboyse's Avatar
rboyse
yes sir 7.3
Old Mar 10, 2011 | 05:56 PM
subford's Avatar
subford
OK some question.
Who told you it was to be no more than 5 Volts?
What does the Throttle Position sensor do?
What circuit is it in?
Is what you are calling TPS the same thing as the Fuel Injection Pump Lever (FIPL) sensor?
wackmaster66
Oct 26, 2011 02:23 PM
74redone
2004 - 2008 F150
Sep 11, 2010 08:18 AM
lakeareastang
Apr 28, 2010 04:24 PM
73cj5
Mar 19, 2006 06:07 AM
arvo
1983 - 2012 Ranger & B-Series
Nov 23, 2002 06:46 PM
