Got them flat cam blues........
Oh-oh.
I have an old Snap-On Counselor II scope, so I plugged her in and did a cylinder balance test and a vacuum waveform. Sure enough, #6 and #7 looked damn near dead. I yanked the driver's side valve cover off and saw right away that the #6 exhaust rocker was flopping around with about 1/4" of lash. #7 & #8 exhaust were also a little loose. I pulled the intake and started poking around. Weird thing was that the #6 lifter plunger was just stuck, with no visible damage. #7 was badly dished, and had stopped rotating at some point, so it was worn off at an angle. #8 was dished, but it wore evenly. I pulled all the other lifters and they looked good.
What I did next wasn't real smart, since I suspected the cam was wasted, but I was hoping to get lucky since I thought I caught the problem right away before the damage spread. Besides, I was supposed to go on vacation this week and I needed the rig to tow my boat, and I was working on it in my employer's shop, so I didn't have a lot of time before he yelled at me to get it out of there. So I was kinda forced into taking a short cut.
I bought a new set of lifters, slapped them in, spun the oil pump with a drill to check for flow at all the lifters, buttoned the rest of it up and started it. I held the RPMs at 1500+ for about 20 minutes to break in the new lifters. About a minute after I dropped it down to an idle, it started the same crap again. WHACK WHACK WHACK WHACK WHACK with a bad miss.
OK, I took a chance, and I wasn't surprised it didn't work out. But what happened next was really a bummer.
I put it in gear to back it out of the shop, and when the RPMs dropped down to 650 or so, the oil pressure disappeared. Zippo. I put it back in neutral, and the oil pressure came back. I revved it up for a few seconds, the pressure held, but when I let off the throttle the pressure went away again when it returned to idle. I was thinking the stock sending unit might be playing games, but then the engine started sounding like a spoon caught in a garbage disposal and misfiring all over the place from the lifters bleeding off.
Oops. Guess I better shut 'er off.
I started it a couple more times, the pressure came back again, and as long as I didn't goose the throttle way up and let it fall back to idle real fast, it stayed good.
So yesterday I tore it down again, and this time I pulled the cam. It's wasted on quite a few lobes, but the journals look good. Just the half hour of running time hammered about six new lifters, including on the other bank where the old ones were still good. I can probably write that off to the previously damaged cam, but the oil pressure thing has me worried. I didn't have any pressure issues when it first went flat. I talked to the machine shop that did my block work, and he thinks the particulate from the cam wear got into the main/rod bearings and damaged them, but I'm not so sure. But on the other hand, I've never heard of a flat cam causing an oil pressure loss. Worn cam bearings will bleed oil off like nobody's business, but that would be a steady loss, not an intermittent "50 lbs one second and zero the next" kinda thing. I felt around inside the oil pan as best I could with the timing cover off, but all I found was clean oil, and no grit or anything else. I spun the oil pump again, and oil was flowing where it should be.
So now a dilemma; I don't want to yank the engine out just to look at the main and rods, since I don't think they're a problem. I didn't really mind wasting $50 and a few hours on a new set of lifters, but it's gonna be a couple hundred $$ and a whole day's work wasted if I eat another camshaft due to lack of lubrication.
Any ideas from the small block types out there??
I think you will find as I have the bearings are waisted.....they will have grooves worn in them right where the oil comes thru the bearing, like it had sand in the oil.
Time for a rebuild......it's no ones fault..it happens.
do a search for camsaft brake in............
do a search for camshaft brake in............
Ditto, the rest of the engine's going to be toast as well as the cam. Loss of pressure was likely the holes worn in the lifter bottoms from riding on the flat cam lobes. As Hemi's said, the rest of the engine bearings are going to be full of metal, ditto for the oilpump. There's no quick easy fix for this.
if the motor is already showing signs of pressure drop then it's likely the inturnals are damaged. if it still had good psi then i would just replace the cam and lifters and run it.
The main thing that is good for a fresh rebuild is the lack of friction modifiers in diesel oils(the energy conserving part) They(Fric mods)will not let the motor wear in right and leading to more fling off of components in the long term(=less lube where you need it) If it says it meets ILSAC put it back on the shelf! The way c rated oils hold onto dirt and other contaminents is what you want so it carries it to the filter and can be removed. I generally use the cheapest diesel oil (15w40) I can find and have run it in my bronco since I bought it 8 years ago, and I change the oil around 5000 miles but I have definately gone longer with it with out a worry. Pulling off a valve cover is all the proof I need after sitting overnight there is still a sheen all over and it is clean no deposits whatsoever or sludge!! Of course there are trade offs!, Zinc from ring and valve seat blowby will foul out a catalytic convertor, If you have one that is!!! and the ash potential is higher which can lead to combustion area deposits leading to pre ignition but a couple of well placed ounces of water will take care of that!! Or some PB blaster in the spark plug holes, let it soak for a while, start and bring it up to 2000 rpm and it will peel it off(don't do this with catalytic converters!) My bronco has 300,000 plus miles and still going strong!! So I will stick with what has been working! When I change my plugs hopefully soon and if this thread is still around I'll post my compression numbers. If you have a fourwheeler or motorcycle run 15w40 in it and it will live a long life and you will not have a slipping clutch like you will get with ILSAC oils!
I bought a new Crane cam, and their break-in lube looks more like a paste or grease than a thick oil. I bought some extra just to be sure I have enough.
I pulled the engine last night, but the pan isn't off yet. I'll know more about internal injuries later.
I helped my friend rebuild a 557 after a bad cam, the cam had like 5 lobes completely gone...truck never sounded right when I heard it for the first time..... anyways we got it apart and the crank was juck it had groves worn right at the oil holes like it had sand pumped thru it. he ended up getting a new block and all new inturnals, saved the heads....
The one thing a always do on any of my motors is ,if a hydo flat tappet with adjustale valve train or a solid flat tappet is mark the rocker nuts after i set the preload. I brake in the cam and re-set the rockers. If I get one that has to be adjust way more then the original mark i put on it I run it with the valve cover off and make sure the push rod is turning. I also check the adjustment a few time in the first 3000 miles. if the cam is ok and everything is right the marks I put on the adjusting nut stay right on the 12:00 position where i marked them. It's a lot of work but if the cams goes bad it might take 10000 miles before you will notice it because sometime! it takes that long to wear the lifter enough to lose all the preload in the lifter. Once the lifter has no more preload in it the rocker starts to tic and you just drove all that way with metal in the oil...
Ok i'm done......Good luck. Glad you are taking the time to check out the rest of the motor....
