'78 F250 Help
Old Mar 8, 2011 | 12:34 AM
dbear75's Avatar
dbear75
'78 F250 Help
I just got a 78 F250 4x4 supercab with a stock 400 and 4 speed manual trans....the truck is stock height and standard tires. The gears are I believe 3.40's...what type of performance and fuel mileage should I expect?
Old Mar 8, 2011 | 01:04 AM
seventysevenF150's Avatar
seventysevenF150
I see you are somewhat new to FTE.. Welcome.. It probably depends on what shape the truck is in, there is a whole bunch of aspects to look at on how well it will perform and what mileage it gets, what shape is the driveline is, so much more comes into play.. plus it all depends on how you drive it too. You might get anywhere between 6-16 mpg or something like that but, theres only one way to find out for sure....
Old Mar 8, 2011 | 07:00 AM
mark a.'s Avatar
mark a.
Probably 3.54 gears.
Old Mar 8, 2011 | 07:38 AM
dbear75's Avatar
dbear75
yeah....I will need to check the gears.....but I am sure they are not 3;73's or 4;10's. at about 60-65 mph the truck is running around 1800 to 1900 rpm's.
dbear75's Avatar
dbear75
Oh, and thanks to the welcome.....I am new to here and new to older Ford's! This is my first one.
Old Mar 8, 2011 | 08:50 AM
fmc400's Avatar
fmc400
MSEE
What is fuel mileage? Do you mean, how many miles to the next gas station?
Welcome to FTE
Old Mar 8, 2011 | 11:52 AM
seventysevenF150
The metal tag on the door will have an axle code. Three digits, two for rear axle, one digit for front axle. Post these numbers and we can tell you what gearing you have, if it's the original gears
Old Mar 8, 2011 | 12:09 PM
seventysevenF150
Here's a quick rundown on the axle codes:
23 Dana 61 3.31
22 Dana 61 3.07
24 Dana 60 4.10
37 Dana 60 3.54
38 Dana 60 3.73
B4 D 60 LS 4.10
C7 D 60 LS 3.54
C8 D 60 LS 3.73
TexasRho83
Nov 14, 2008 01:20 PM
bubbas78f250
Apr 19, 2008 02:16 PM
78fordf250-460
Nov 5, 2005 08:00 PM
78f250_rls
Oct 3, 2005 03:15 AM
