Ignition switch
Old Mar 7, 2011 | 06:10 PM
jcahicks's Avatar
jcahicks
Ignition switch
I lost my keys the other day and come to find out it was the only set of keys to my 71 pickup. So I went down today and bought a new insert to go in figured it to be a 5 minute fix. But I need the old key to turn the switch in order to push the plunger in to take out the old one. The new key wont work. Does anyone have any ideas on how to get around this? 71 Half ton 4x4
Old Mar 7, 2011 | 07:12 PM
tmcalavy's Avatar
tmcalavy
The right locksmith can do that for you, they have the tool/key to release the switch so you can replace it.
Old Mar 7, 2011 | 07:26 PM
jcahicks's Avatar
jcahicks
I was hoping not to hear that. Probably my only aternative huh?
Old Mar 8, 2011 | 04:33 AM
Talltruck's Avatar
Talltruck
Sometimes another similar key will work if you put it in the switch and wiggle it while you're turning it.
Old Mar 8, 2011 | 06:06 AM
60F100's Avatar
60F100
You can drill it out, but be careful.
Old Mar 8, 2011 | 10:07 AM
Alex from GA's Avatar
Alex from GA
Look in your other jacket.
Old Mar 8, 2011 | 12:17 PM
CougarJohn's Avatar
CougarJohn
Why not remove the old switch and replace it with a new one with the new key insert?
Old Mar 8, 2011 | 09:49 PM
orich's Avatar
orich
10-4 On replacing the switch. But remove the old one first to see what type you'll need. Theirs a few different one's or someone may have changed the OEM one. There's one that has round contacts pins & one with flat spade ones. This way you'll know which one you'll need.... I would think a locksmith would cost well over a 100 buck
orich
bwalt11
26
Aug 3, 2016 08:03 PM
tractormanbill
Jul 19, 2014 10:33 PM
Blythewoodjoe
1997 - 2003 F150
Mar 11, 2013 09:56 AM
dfwrider
Dec 4, 2007 05:15 PM
yota
Mar 3, 2004 06:09 PM
