I am wanting to replace the rusted out doors on a 88 F250. What years will bolt right on? Also, will F150 and F350 doors from the same year range work also? Thank you.....
They are the same from 80-96 on the F-150,F250,F-350,F-450 & F-550 except the mirrors are different and some of the detail lines on the bottom of the doors on the 95 and 96. The doors on a 97 F-250 & F350 will also work. You should also be able to take out the glass,locks ect... and put them on your new doors.
Good Luck.
