I am planning on buying a levling kit / Bilstein shock combination for my 2005 Ford F250. I would like to see if anyone has any suggestions on making the installation easier. Better yet, does anyone have instructions on how to install it? Do I need a tool of some sort to compress the coil springs? Thanks for the help!
So I unbolt all these parts while the truck is still sitting on the ground and then jack up the bumper? Then take the wheels off and I should be able to remove the springs without compressing them?
hell i did mine without a spring compressor. its easy. like they said unbolt all that stuff but i jacked the bumper up first. use jack stands under the axle if you take the tires off. i took my tires off to make it easier but if your small enough you can do it with the tires on and they act like your jack stands
