Leveling Kit Help
Old Mar 6, 2011 | 07:30 PM
onuredneck707's Avatar
onuredneck707
Leveling Kit Help
I am planning on buying a levling kit / Bilstein shock combination for my 2005 Ford F250. I would like to see if anyone has any suggestions on making the installation easier. Better yet, does anyone have instructions on how to install it? Do I need a tool of some sort to compress the coil springs? Thanks for the help!
Old Mar 6, 2011 | 07:48 PM
clane's Avatar
clane
unbolt shocks trackbar swaybar and jack up the bumper
Old Mar 7, 2011 | 07:01 AM
onuredneck707
So I unbolt all these parts while the truck is still sitting on the ground and then jack up the bumper? Then take the wheels off and I should be able to remove the springs without compressing them?
Old Mar 7, 2011 | 02:20 PM
smokersteve's Avatar
smokersteve
You will want to get a spring compressor. That helped with my 2.5" spacers.
Old Mar 7, 2011 | 05:54 PM
clane's Avatar
clane
i didn't use one just watch vacuum lines to the hub's wheels on
Old Mar 7, 2011 | 07:25 PM
Ian123's Avatar
Ian123
its alot easier with a spring compressor but you can do it without
Old Mar 7, 2011 | 07:29 PM
rdunagan's Avatar
rdunagan
hell i did mine without a spring compressor. its easy. like they said unbolt all that stuff but i jacked the bumper up first. use jack stands under the axle if you take the tires off. i took my tires off to make it easier but if your small enough you can do it with the tires on and they act like your jack stands
Old Mar 30, 2011 | 06:31 PM
John Luther's Avatar
John Luther
Definately....
