First tow experience
Both ours and the LML Duramax have motor driven throttle plates to control the intake versus exhaust pressure to assure positive EGR flow. They don't function like a gasser in terms of actually throttling the engine but they are there. Ford calls it an Intake Throttle Body not me.
I don't want to start a poop storm but let me get this straight,
1. Tow haul mode
2. Initial speed below 52
3. Trans will downshift as required to maintain 52 till 4000 rpm.
Is that what I should expect? I just want to know how people who have had success with the function manage it.
FWIW there is no software that will change this situation it will require hardware mods to really increase the effectivity.
Again I really like my truck I just want to know it better.
It's true, my rig is lighter than yours... but nobody ever said that the improved engine braking mechanism is going to replace a jake brake. If you're towing that heavy, buy a jake brake!
Every time this subject comes up, I'm reminded of all the iPad-related posts. "what? it doesnt do XXXX? That will never replace my laptop!"... well DUH... the iPad was never supposed to replace a laptop, and nobody from Apple ever suggested otherwise. Just like this isn't supposed to replace a jake brake.
to further my point: your truck has tow hooks, right? then why do you need a winch?
For many of us, myself included, the integrated engine brake works very well. I use it as instructed, and it works AS DESCRIBED.
I agree that it could be stronger but it works far better than any other truck I have owned. I operate my truck within it's design limitations and so far it has worked out well for me.
I like the oatmeal raisin cookies best...no milk...coffee instead
Regards
I *do* wish that Ford at least offered a factory "big rig" style exhaust brake as an option on the 6.7L. They do not. Instead, they have an integrated version that does its job very well... it just doesn't do the same job that lots of people mistakenly think it should. Or it doesn't do it the same *way* they think it should. Or whatever... but the point (and lots of counterpoints) has been made. a LOT. Everyone is, of course, entitled to their opinion of the system. Just PLEASE do not judge it by the wrong standards. That is exactly what is happening here... and exactly what I was trying to prevent.
Regards
I wish that I'd have been aware of this particular 'design limitation' of the truck before purchase. Shame on me for not getting the real world scoop from other owners that tow rigs as heavy as my own.
Steve
Steve
I can say with confidence that downshifting via the M mode is not as effective as using the integrated engine brake. It's a similar feeling, but a totally different sound, a different level of control (tap once per "notch" that you want to slow down to), and under heavy, near-emergency braking, it's automatic. The next time I have the fiver hooked up, I'll do some real-world tests in as scientific and unbiased way I know how. I have basically done these already, just didn't record any results or ensure a scientific method.
I'm not sure I've ever posted this on any of the other 100 threads... but FWIW, I found the engine brake by accident. I knew it was on there, but the "integrated" term and the fact that I've never owned a diesel with a jake brake (and therefore wasn't expecting a jake brake) made me assume that it was just one more "magic" thing that happened behind the scenes. Not so much. I first found it in a near-emergency stop. I was towing the fiver and 4 total adults (plus dog). Full loaded, as heavy as I get. I was doing about 40 mph and looked down for a split second, then up to see a light that was already yellow, and still a few hundred feet in front of me. I needed to stop NOW. I asked the truck and trailer to lose that speed, STAT. The transmission downshifted and the engine screamed... but the TURBO took on a whole new attitude. It belted out a tune that I had never heard before... and the truck stopped. WAY faster than I expected a combined 12 tons to stop. AND there was no burning brake smell like I expected.
Once we got to the campsite, I hit up FTE and found one of Rickatic's posts that described the tap-to-slow pedal control. I used it the next day on the way to the next stop. I was impressed! I then played with it on every downgrade for the next 50 miles... and we were in the TX Hill Country, so there were a lot... my wife eventually asked "WTF?"
Again, every driver is entitled to feel differently from the way I feel. That said, I have experimented with this system quite a bit in my 5k+ miles towing with it. I figured out how to make it work for me... and I am confident that it will work even when I don't have a chance to give it any warning.
I conceded a long time ago that the EB is not up to the level of the competition. So be it...I also know that the heavier loads tax the system more than my 13000 pound fiver does. I maintain that we must operate these trucks, not just sit there and let them drive us. Like any piece of equipment, knowing its operating parameters will make for a more successful experience. JMO
Regards
Steve
I've owned 4 diesel trucks including this one
None came with assisted braking - including this one
Thanks for your testimony on M mode versus Tow Mode. I admit that my fear of over revving this expensive engine could be contributing to my level of dissatisfaction.
Rick's tip on tapping is now part of my regular routine. It forces the tranny down a gear which is how my 2008 F250 worked.
My wife says WTF in reaction to the smell of hot brakes at the end of a long grade. I hear extra about it because she remembers the cost of parts when I installed a jake on my Dodge. Prior to purchase I assured her that Ford addressed this need at the factory
My take is that Ford saved a little money with their 'system' when compared to an actual exhaust brake. While it reportedly works fine for lighter trucks with lighter loads, it is lacking for those of us that tow heavy.
Hey I am still liking the fact that my 06' 6.0 with the TS trans and Tow/Haul mode, slows the truck and trailer down like it does,,,Nice feature!
Also remembering when we pulled camp trailers and Boats with a 71' F-100,,,302,,3 on the tree, No Trailer Brakes, very little Power,,,,Pickups have come along way !!
