1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Truck dies when turning steering wheel
Old 04-03-2011, 08:56 PM
manuel transmission's Avatar
manuel transmission
manuel transmission is offline
gah....I'm starting to hate this thing.
Checked wires...they all looked fine.
So, at this point in time, the truck will do three things:
1. Run fine. Super fine.
2. Stall for no reason. Instantly cut out if I'm sitting at a red light, or if I'm at speed and let my foot off the gas. Not all the time mind you, just sometimes.
3. ....and recent discovery since I drive like grandma. The truck does the same thing when I floor it and the RPM's reach the higher end of the spectrum. I know I'm not hitting the rev limiter because it would not act like this with the old motor.
I'm thinking of starting at the throttle position sensor. What do you guys think?
  #32
Old 04-03-2011, 09:22 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Did the TPS come with the engine or is it from the original engine? In any case they are not too expensive and they are easy to install. At this point I would try it.
  #33
Old 04-04-2011, 11:37 AM
manuel transmission
It was on the old engine. I think I'll tackle it today.
  #34
Old 04-04-2011, 08:47 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Good idea as it might have been ready to fail when the old engine died.
  #35
Old 04-06-2011, 09:38 AM
manuel transmission
had enough. Didn't want to replace parts when I wasn't sure what it was. Took it to the shop. Bad crank sensor. They said it kicked a code, but when I had Auto Zone check it, there was no code. Who knows, I'm happy though. $170 to fix it.
And now it's time to sell it.
  #36
Old 04-06-2011, 10:10 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Glad to hear that it's all good now.
If the shop gave you the old sensor you should examine it closely to see if any wires appear pinched ot broken internally. Not to fix blame on anyone but, for the knowledge of the group here at FTE. The installer may have accidently damaged the wires while doing the R&R and just transferred the sensor to the new engine without noticing a potential problem. You might also show whatever is found to the installer so he might be a little more careful the next time. If it's the same shop they should only charge you for the sensor.
Have a great day and happy motoring.
  #37
Old 04-06-2011, 10:26 AM
manuel transmission
The shop that did the new engine instal is in NY, and I'm in FL so there isn't much I can do about it. I should be getting it back in an hour or two.
  #38
Old 04-06-2011, 11:23 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
I understand that,. If you have the opportunity to look at the old sensor, the appearance of the wires would be good to know.
  #39
Old 04-06-2011, 11:24 AM
manuel transmission
Oh, OK. I'll see if I can get my hands on it.
  #40
Old 10-03-2018, 04:45 AM
Jordo909's Avatar
Jordo909
Jordo909 is offline
What mechanic should i take my truck to?
I have a 1986 Ford Bronco I have a smillar issue. It turns off when fully turning right or left mostly when parking. As I turn it ither direction it will make a very loud skreeching sound, or shut off.
should i take it to a steering wheel specialist or someplace to clean and replace the IAC valves?
jmccart
10-10-2023 03:16 PM
Nbing
07-19-2017 03:43 PM
jmccart
1999 to 2016 Super Duty
13
01-09-2017 10:24 AM
odawg
12-22-2015 11:01 PM
danedaddy25
11-03-2012 08:31 AM
Quick Reply: Truck dies when turning steering wheel
