Engine replacement '79 F100
Old Mar 5, 2011 | 10:56 PM
NewOwner1979's Avatar
NewOwner1979
I was planning on rebuilding the 351M that is suppose to be in my truck. When i had it busted down all the way, I looked at the block and saw that it was cracked. BUMMER!!! Now I want to put a smaller engine in it. What would be the best size to replace it with? Any suggestions would be greatly appreciated.
Old Mar 5, 2011 | 11:56 PM
DCFord's Avatar
DCFord
302 is an awesome motor.......plenty of power and you would get a bit better gas mileage.
Old Mar 6, 2011 | 10:44 AM
79 f350ts's Avatar
79 f350ts
keep in mind, if you swap to anything other than 351m,400 or 429/460, you will need to get the tranny too
Old Mar 6, 2011 | 10:50 AM
arctic y block's Avatar
arctic y block
351W would be my choice.
Old Mar 6, 2011 | 10:57 AM
bucks77ford's Avatar
bucks77ford
You could also think about adding an AOD transmission to a 302 and have a really nice cruiser. Otherwise, the 300-6 is a great motor.
Also keep in mind on what 79 F350ts said.
Old Mar 6, 2011 | 11:12 AM
HIO Silver's Avatar
HIO Silver
After reading the post, my intial thoughts were "why go with a smaller engine? and "what is the truck used for?"
Nonetheless, any smaller engine would requre a different tranny so that'll come into play with whatever engine you decide upon. With that said, the Windsors (260, 289, 302, 351) are provided aftermarket support options. A 302 can be stroked to a 331 or 347 and the 351 can be stroked to a 392 or even a 427. Your call on what your budget allows.
Perhaps a more economical option is the 300-I6. Good torque and decent gas mileage. The intake manifold is a dog and runs lean in cylinders 1 and 6. Aftermarket support isn't all that good BUT it won't involve alot of hassle with matching up parts to the frame like a 351W since it wasn't offered in 73-79s and has a taller deck height than the 302 - important if you want to run headers.
In the end, I'd go 302 (or 331) or the 300-I6... with the latter only for gas mileage reasons.
Old Mar 6, 2011 | 11:32 AM
79 f350ts's Avatar
79 f350ts
agreed 302 best all around choice, if your not gonna beat on it too much. And since youll need a matching tranny anyway, an aod would boost mileage even more.
Old Mar 6, 2011 | 01:20 PM
77h0t_r0d_wrecker's Avatar
77h0t_r0d_wrecker
300 all the way! Stout engine that will run forever and it will out pull a 302 any day. Plus you can pick up everything needed at your local pick and pull yard, I'm sure they have at least 1 f100 with a straight 6 in there...
EDIT: And if you go with the 300, you can put EFI manifolds on it, Offy intake, 4bbl carb and so on for under 1k and have a decently powered workhorse that will get better gas mileage than your 351. Take a look in the 300 forum, lots of info in there.
Old Mar 6, 2011 | 01:27 PM
impalaslayer's Avatar
impalaslayer
i have a worked 289 in mine. seems to have good power, havent really gotten to drive it much, still trying to get it road worthy.
Old Mar 6, 2011 | 03:56 PM
George Frasier's Avatar
George Frasier
Of a "smaller engine", I'd go with the 300 I-6 for the little loss in HP you'd make more torque.
Old Mar 6, 2011 | 04:27 PM
bamaf150's Avatar
bamaf150
Ditto on the 300, if you plan on driving it much and gas going well north of $3.00. I would rather have a 300 than a 302, in a pickup anyhow.
Old Mar 6, 2011 | 04:42 PM
NewOwner1979
Thanks guys. I'll look up prices for a 302 and 300. I knew I was going to need a new transmission. Wish I didn't though. Don't really have that kind of money right now.
Old Mar 6, 2011 | 07:00 PM
NewOwner1979
I believe I am going with the 302. Engine and transmission will run me a little over $2000. Hopefully I don't run into anymore problems with this truck. Whoever had it before me messed up the wiring pretty bad but that's an easy fix. It will take a while but i will try to post pics when it is complete.
Old Mar 6, 2011 | 07:16 PM
bucks77ford
Good luck with it and we'll be waiting for the pics.
Old Mar 6, 2011 | 07:40 PM
77h0t_r0d_wrecker
$2k for engine and trans? Used? That's a bit much. I'm sure you can get a running 300 from the scrap yard plus the trans for probably around $5-600.
Not to mention everything you would need to do the swap.
Hell I have a perfect T-18 or 19 (not sure which but its the cast iron 4spd w/ granny gear) That I'd sell you for $100, she needs a clutch though. I don't know where you're located though so shipping might be high.
JMO but $2k for an engine and trans is too high man, especially if it's a pure stock 302 with miles on it, and the units aren't rebuilt. I have a feeling you're going to spend that money and be a bit disappointed, but hey, it's your truck
