Replace Driver's Seat
Old Mar 5, 2011 | 10:39 PM
Ben-K's Avatar
Ben-K
Question Replace Driver's Seat
The driver's seat in my 1995 Explorer has fallen into the power works under it, and I need to get it replaced. I'm pretty sure I can find a seat in a local junk yard that will fit, but what kind of shop to I go to to have the work done? Upholstery? Body & fender?
Old Mar 5, 2011 | 10:47 PM
Chaosracing's Avatar
Chaosracing
If you are just doing a swap, its really not that hard. Just undo the 4 bolts and undo the wire harness under the seat and pull it out. Do reverse to put new one in. Now if you want to recover it, then a auto upholsterer is where to take it to.
Old Mar 5, 2011 | 11:11 PM
Ben-K's Avatar
Ben-K
For the power seat? That's all there is? What about the track, motors, etc?
Old Mar 6, 2011 | 01:11 PM
Chaosracing
The track and motor are attached to the underside of the seat. There are 4 bolts that hold the track down to the floor board. Remove those and disconnect the plugs and you can remove everything as a unit, much like how they install them at the factory. Then you can do what you want to the seat.
Old Mar 28, 2011 | 03:20 PM
JakeZ's Avatar
JakeZ
put brides in it.
Strummer
1983 - 2012 Ranger & B-Series
May 24, 2012 07:28 PM
mrjenkins
May 10, 2008 09:16 AM
jmurray205
May 29, 2005 10:59 PM
cwh82
Oct 6, 2003 08:40 AM
saanders
1978 - 1996 Big Bronco
Aug 27, 2002 08:57 AM
