I found the floor rusted out in my 85 F150,,,I found water had leaked into cab from somewhere when it rained. Anyone else have this problem..This is not the first Ford I have had to replace the driver side floor.
My 85 F150 does this too. In my case, the culprit is crystal clear. It is the seal around the windshield. When I am driving on rainy days, I will actually have an occasional drop of water roll down the inside of the windshield. My windshield just happens to also have a glaring crack straight down the middle too. I'll be replacing it when I get my income tax refund... I suspect it will solve the leaking issue.
Windshield just replaced and rear window is slider and does not leak..Seems to come in around the kick panel. I thought I had found the culprit area when I replaced the windshield. I cant hose the truck down with water for a month or so,,,too cold up here.
last fall i had the cowl off to clean out and I put seam sealer down in there as I thought that was where it was coming from. All the seam sealer in there was dried and cracked.
