ccv mod vote
Old Mar 5, 2011 | 10:28 PM
ScaldedDog's Avatar
ScaldedDog
Great idea. Where did you get the 4" piece of SS tubing? That seems like the only part that couldn't be found at Home Depot.
Mark
Old Mar 5, 2011 | 10:44 PM
white Buffalo's Avatar
white Buffalo
I've had the CCV mod on my F-250 vented to atmosphere for 5+ years. Works for me.....Will do the same to the 2000 Excursion I just purchased.
Old Mar 5, 2011 | 10:51 PM
Bonanza35's Avatar
Bonanza35
Originally Posted by Fat Diesel
My lone vote is for the CCV into the exhaust. I've heard everything from 1psi overpressures are going to blow seals to claims that the exhaust is corrosive and will go backwards through the hose and into your valve cover. Well today we're going to pull that valve cover and see what it looks like in there after more than 100,000 miles in this configuration. I do occasionally see a little vapor blowing by the truck, but it's coming out the exhaust pipe. I KNOW everybody thinks it's a bad idea (mostly based on testimony of theory and loosely based on pressures measured without load), but those who have done it in mild climates have had a lot of success with it.
I for one love it and will be sorry to see it go back to stock when I have to make my first smog appointment ever, in my life, for anything. Probably will put it back in the exhaust though. Today's exploration will largely determine it's ultimate fate. Pics to follow.
Here's the config.
I like this idea. Its the way they did in the 70's for race cars. I don't know if they still do this but it is suppost to help suck out the vapors and vent the crank case. Someone here said it pressurizes the crank case but I don't believe it dose. Haven't done it but the above pictures shows it works. My 02 cents
Old Mar 5, 2011 | 11:49 PM
Ponyboychris's Avatar
Ponyboychris
Mark
There was a member here selling extra pieces from his exhaust install. You can also find a piece here: Exhaust Tubing
Old Mar 6, 2011 | 01:42 AM
SLUF681's Avatar
SLUF681
Mark
Go to any exhaust shop and ask for it. If they don't just give it to you, they won't charge you more than a couple bucks. It'll be cheaper than shipping charges.
Old Mar 6, 2011 | 03:11 AM
Larry_the_handyman's Avatar
Larry_the_handyman
I'm definitely doing it. My intercooler boot has a hole in it and is spraying oil mist all over my engine. I don't care how oil-resistant the new boots are, I'm not risking this crap ever again. Plus at higher boost pressures the boots have a hard enough time staying on the tubes without being coated with oil.
I'm running a 3/4" hard line from the firewall to the rear of the cab to prevent puddling in the tube. Has anyone ever tried running a hard line up against the exhaust to help burn off some vapor and/or keep the SOS pad filter from freezing in cold weather?
Old Mar 6, 2011 | 09:11 AM
Ponyboychris
Originally Posted by Larry_the_handyman
... Has anyone ever tried running a hard line up against the exhaust to help burn off some vapor and/or keep the SOS pad filter from freezing in cold weather?
Honestly, I've never had any issues with my SOS pads. I've recently started using the plastic ones verses the copper ones when I built the traps for members because they are easily available and just as efficient. They are porous enough to not get gummed up. I'll take a pic of my scrubber pads today and post them. It's been a few years since I've installed my trap and never had any freezing issues in either the line nor the trap.
Old Mar 6, 2011 | 02:55 PM
Fat Diesel's Avatar
Fat Diesel
I think we can finally put to bed the "speculation" that corrosive gasses will be forced back up the CCV hose into the valve cover if routed to the exhaust. I pulled my valve cover after well over 100,000 miles on this mod. What did I find? Beautiful clean parts with a light covering of oil. No soot. No corrosion. Nothing to suggest that exhaust gas EVER gets pushed back up the hose.
Old Mar 6, 2011 | 03:14 PM
bulla's Avatar
bulla
What's the difference in the back two injectors for them to be yellow? Have they been replaced? Just curious!
Old Mar 6, 2011 | 03:16 PM
SkySkiJason's Avatar
SkySkiJason
I did it and I hated it - it STINKS. There is no measurable benefit. Even if you 100% eliminate this tiny amount of oil there will always be some in the CAC. Upgrade to Riffraff boots and CHECK for leaks and the 'oily boots' go away.
Besides, a little oil can't hurt the turbo and God forbid could trap some debris in the event of contaminated air!
Whats the point?????
The boots with a hole in them were not just because the OE boots 'aren't compatible' with oil - that claim was overblown by the first people selling 'aftermarket' boots. They are thin and more susceptible to wear than Clays boots though.
Old Mar 6, 2011 | 03:42 PM
Fat Diesel's Avatar
Fat Diesel
Yep. They were replaced with new Alliant Power ones about 150,000 miles ago.
Old Mar 6, 2011 | 04:34 PM
F-250 Super Duty's Avatar
F-250 Super Duty
I'm torn on the idea. I'm getting ready to do a non wastegated housing and deleting the epbv with a new pedestal. I just pulled my intercooler pipes and painted them. Yes there was some oil residue in the pipes but not nearly as bad as I would expect reading some posts. Here is my other thought..... Are the guys doing this mod taking the intercoolers out of their trucks and flushing them out? It seems to me that the oil would puddle at the lowest point (bottom of intercooler). So to me the idea of the mod removes future oil from being introduced into the system but what a out the trucks that have 100+ thousand miles of oil in the intercooler. Wouldn't that just be redistributed throughout the system? This is why I haven't done it yet nor am I certain I will. To me a little lube on the turbo is ok with me.
Matter of fact I just watched a show today that advertised an additive to engine oil to help it make it to the turbo..... I already have that. Lol
Old Mar 6, 2011 | 04:42 PM
  #28
bulla's Avatar
bulla
Like I said I don't have a mess since I went with clays boots but how much oil is collecting in the cooler? Unless there is enough air flow to clean it out it seems like it would fill up over time and collect heat. Not sure though. Surly someone has pulled their innercooler off after 200,000 miles and has seen! Anyone?
Old Mar 6, 2011 | 04:57 PM
  #29
SkySkiJason
No, it was over 300k though... After being tilted on end for WEEKS there was a puddle that was easily wiped up with a couple shop rags. That was after having a crack/hole in a piston - can you say 'blow-by'?
When I pulled (new) engine again a year later I tipped it up again and low and behold - MORE oil came out. Not much, but it obviously didn't all drain out the first time.
Old Mar 6, 2011 | 05:18 PM
  #30
bulla's Avatar
bulla
Cool! With the upgraded boots I don't see it necessary then! But every one is entitled to their own opinion!
