Sponsored by: Real Truck
O2 Sensor System Not Reading
Old Mar 6, 2011 | 11:10 PM
Bigpipes 35's Avatar
Bigpipes 35
Sorry cant get pics to load I will keep trying.
Old Mar 7, 2011 | 01:26 AM
_Rick_'s Avatar
_Rick_
The photo you had in this post was working earlier. Seems to be gone now.
Rick...
Originally Posted by Bigpipes 35
Lets try this JD does you sticker look like this?
Old Mar 7, 2011 | 08:47 AM
Bigpipes 35
Hey rick I saw the photo was working I used photobucket but I noticed that it linked my wifes facebook account with it as well and I didnt really want that so I took It off. I have to figure out how to get just the pic like you have on your reply any suggestions. What I did was right click the pic in photobucket and copy it then I pasted it in the reply box.
Old Mar 7, 2011 | 02:07 PM
_Rick_'s Avatar
_Rick_
When replying to posts are you using advanced edit or quick reply? If you use advanced there are many options available to post things like editable link titles and images etc,,,
I generally try to only post photos that I am confident will be available to FTE users for years to come so I try to only post photos I have stored in my photo albums here on the FTE servers. It can also be a pita when looking for help from photos and also not look very clean when a thread is loaded with dead links to outdated/long gone websites.
With that in mind maybe you might consider uploading photos to your FTE album. It also makes it very easy to post them here. When you open the photos in your FTE album it provides you with the code below the photo to input into your post.
It takes a bit of getting used to accessing and using all the options available in your User CP (User Control Panel), but after a while and a little effort correcting your posting mistakes many times you'll get the feel of it.
Rick...
Old Mar 7, 2011 | 05:17 PM
Monster-4's Avatar
Monster-4
Originally Posted by jd1083
My truck needs to be inspected which here in North Texas means an emissions test and computer scan. When I plugged my code reader in it didn't bring up any codes but it showed that the O2 sensor system has not run its full system test. I know this can happen if the battery has been disconnected recently and before I bought the truck it had a battery replaced, but I've put almost 1000 miles on the truck since I purchased it 2 weeks ago so I know it has had enough time/miles to run it's test.
What could be causing the truck not to run it's full set of tests? I did notice that the truck only has one O2 sensor on it (pre-cat) instead of the four that I thought it would have. Is this normal and if not could this be causing the system not to run a full test?
What year? 99-04 will only have two O2 sensors (one on each side of the y-pipe before the cat) and will not have post cat O2 sensors. This is normal.
Old Mar 9, 2011 | 10:51 PM
jd1083's Avatar
jd1083
It's a 2001 so I guess the two O2 sensors are normal then. I'm going to try the procedure that is in the link you posted tomorrow Rick, hopefully it will help the computer run it's full diagnostic checks.
frosty95
18
May 13, 2016 09:21 AM
omar1746
Mar 15, 2016 08:43 PM
dpassarella
Mar 30, 2014 07:55 PM
alie-r
13
Jun 5, 2012 01:50 PM
Frodo79
1983 - 2012 Ranger & B-Series
13
May 20, 2012 04:04 PM
