Valve spring help
Old Mar 6, 2011 | 08:40 PM
  #31
7.3 Rocket's Avatar
7.3 Rocket
Originally Posted by rat49f6
not with an attitude like that
Not without a torch set, impact gun, and 15 cans of PB blaster. You guys are thinking of YOUR trucks... not mine.
Old Mar 6, 2011 | 08:55 PM
  #32
Ziggy.'s Avatar
Ziggy.
Originally Posted by 7.3 Rocket
I'm quite positive I couldn't do an axle swap in the middle of a KOA campground with the tools that I've got on my truck. Therefore you win.
Lmao that was an easy one, we can pull a motor this year if you want.
x2
The stuff at work is usually alot lot worse than your truck petey. It's not too awful bad.
Old Mar 6, 2011 | 09:00 PM
  #33
7.3 Rocket's Avatar
7.3 Rocket
Nah I've already done that with a 6.0
how about 5 minute nitrous install lessons?
And did you look AT my truck or did you look under my truck? It looks fine from 100 feet away. Go under it and tell me it's not bad...
Old Mar 6, 2011 | 09:51 PM
  #34
Ziggy.'s Avatar
Ziggy.
5 min nitrous I can teach easy
Yes I know what your truck looks like underneath. Thats the way stuff is underground at work. 100% humidity and its like throwing parts in saltwater. Let me put it to you this way-I don't wipe the oil or grease off my tools because that will rust within 5 days if I clean them.
Old Mar 7, 2011 | 10:27 PM
  #35
duck fan's Avatar
duck fan
Because racetruck
Originally Posted by ron's power stroke
Originally Posted by TARM its not only boost but RPM's as well..its nice to have a balanced out motor..this is what i was told...You should do them but some guy's dont. Nice to get 125 seat pressure up from stock which is 70-75 and that is new. Wonder what it is with a 100K plus on it. Based on Comps spec sheet if you install and shim to spec you will have 125lb seat pressure. Page 3 of 6 the 3rd in from the far right #910
If you have the time and want to do it "the correct way" you should measure each one and use a combo of shims if needed to get them all as close to the same height as possible.
It could take different shim sizes depending on wear. Jegs has a variety pack of harden shims 16 per size 0.015, 0.030, 0.060 Jegs Part #555-20591 That with a valve spring micrometer Jegs # 555-80535 and you can shim them all to the correct height. You will then know what you have. They have a 1.28 max bind height and maybe someone else can given the amount of lift from the stock cam then you could error on the side of slightly lower height and get more seat pressure. Key is you want a safety margin between max bind height and the actual height. something like 1.685-1.700 I seem to recall. But you NEED to Double check that number from someone that knows for sure. That would put it somewhere around 150lb.
Thanks for copying that info over here Ron. I have had that post from PSN saved since it was posted in January. I am planning on putting springs in when I do my injectors in a couple of weeks. With 250K+ on my motor I figure my stockers are pretty worn at this point.
Old Mar 7, 2011 | 11:42 PM
  #36
ron's power stroke's Avatar
ron's power stroke
no problem..that is why i said "this it what i was told".. Tarm is very smart when it comes to these mods....its funny when i post links over here from PSN you hit that little red flag button..
Old Mar 7, 2011 | 11:51 PM
  #37
duck fan's Avatar
duck fan
Because racetruck
No buttons hit here except "reply". Just want to make sure credit is given where it's due.
Old Mar 7, 2011 | 11:53 PM
  #38
ron's power stroke
LMAO ok....
any one want to buy a bridge???
Old Mar 7, 2011 | 11:59 PM
  #39
duck fan's Avatar
duck fan
Because racetruck
LMAO ok....
If you really want to go there Ron...
You were never "told". You never posted in that thread on PSN. You saw a thread here, did some searching there, copied and pasted to make yourself look good. I tried to give credit properly without making you look bad but that wasn't enough for you.
Sorry.
Old Mar 8, 2011 | 12:10 AM
  #40
ron's power stroke
are you reading my PM's over there??? he PM'd me that post thats why i never posted in that thread.. i said this IS what i was told..not this is what i would do...the mod's here are sick of the red flags for me posting PSN links and links to there sponsors....why do you think i dont post them any more??? me look bad ??? LMAO i dont think im the one looking bad..you fallow me around nagging ole lady and try to correct every thing i say or do...i dont take or want credit..just spreading free info around...
Old Mar 8, 2011 | 12:16 AM
  #41
hucka1a's Avatar
hucka1a
LMAO ok....
This bridge?
I want my supporter logo gone..I cant be apart of this place any more.....
Old Mar 8, 2011 | 12:24 AM
  #42
ron's power stroke
lol yes thats the one.... over a month ago and he still fallows me around...go to my profile and click on all threads i have posted in...ill bet you find he post right after me in just about every thread.......
Old Mar 8, 2011 | 12:25 AM
  #43
duck fan's Avatar
duck fan
Because racetruck
Out of the last 14 threads you've posted in, I've posted in 2...
I bet you'll find I post in other threads right after other people too. Do I follow them around too? Not to mention in that thread you posted 3 or 4 times, I only posted once, after someone else. Maybe I was following them.
Old Mar 8, 2011 | 12:43 AM
  #44
ron's power stroke
maybe your little rubber ducky is lost and you need to take it out on some one...i guess i can take it..i dont need to run to the mod's for protection...its time for me to go to work...
Old Mar 8, 2011 | 07:00 AM
  #45
izzybird's Avatar
izzybird
Can y'all hug or something cause this is Lame.
And has been.
carguy3j
May 20, 2017 09:04 AM
Raleigh1
1966 - 1977 Early Broncos
Aug 2, 2016 10:36 PM
Joel Cassell
Apr 3, 2016 08:12 PM
markland
Feb 27, 2012 02:36 PM
Furyus1
Feb 20, 2010 11:52 AM
