Is this a flathead tool?
Old Mar 3, 2011 | 08:09 PM
52 Merc's Avatar
52 Merc
I found this on craigslist advertised as a flathead valve spring compressor. Is it worth having in my toolbox?
Old Mar 3, 2011 | 08:52 PM
kenjh's Avatar
kenjh
I don't know how you could get that in the lifter galley to use it...how often do you work on your valves??short answer...I don't know ...but it looks neet!!
Old Mar 3, 2011 | 08:59 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Not totally sure by the size, but I helped restore an 8N Ford Tractor a few years ago and the one I used to get the springs in and out of that worked the same general way. It looks like an oversized compressor for a Briggs and Stratton!
Old Mar 3, 2011 | 09:30 PM
mtflat's Avatar
mtflat
Keep in mind all mfg's had flatheads - I don't recognize it as anything Ford, but what do I know?
Old Mar 3, 2011 | 09:38 PM
52 Merc's Avatar
52 Merc
I talked to the guy and he said it was a Ford flathead spring compressor. My thought was you would use it after removing the valve/spring/guide assembly from the block? Thoughts??
Old Mar 3, 2011 | 09:45 PM
49fordpickumup's Avatar
49fordpickumup
It's a colonoscopy tool. TEE HEE chuck
Old Mar 3, 2011 | 09:56 PM
havi's Avatar
havi
I'll have the Roast Duck
pear of anguish? The shop manual doesn't show any tool looking like that, so I don't know.
Old Mar 3, 2011 | 10:05 PM
larryb346's Avatar
larryb346
I can see how it could work, but depending on the tool size I think it would be very hard to use in the limited area in the galley.
I think it might be better suited for use on a Flathead straight 8 like a Pontiac or straight six Flatheads where you have more room.
There are much better designed valve spring tools that that one.
Larry
Old Mar 3, 2011 | 10:15 PM
52 Merc's Avatar
52 Merc
Overall length is said to be ~9".
Old Mar 3, 2011 | 10:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've seen those, they are an adaptation of the B&S tools. It wouldn't be the first one I reached for on a V8, but on the straight flat-6's it is probably a great tool.
Wayne, once the valve assembly is out of the head, you don't need any tools to assemble/disassemble. There's no pressure.
Old Mar 3, 2011 | 11:08 PM
kenjh's Avatar
kenjh
at this point ..it would seem that you won't need it in your tool box..but ...it might make a good hammer..........
Old Mar 3, 2011 | 11:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
This is the more common compressor-type tool; made by K-D
flathead engine valve spring tool ford chrysler dodge - eBay (item 110654351018 end time Mar-05-11 18:00:00 PST)
Another one by Sunnen
http://cgi.ebay.com/ebaymotors/SUNNE...motiveQ5fTools
Old Mar 4, 2011 | 12:00 PM
jmadsen's Avatar
jmadsen
I thought this was the original Vintage prostate spoon ???
1932-45-53 FORD~CHEVY~BUICK VINTAGE FLATHEAD VALVE TOOL - eBay (item 330535095776 end time Mar-06-11 17:00:00 PST)
kens65fb
Jun 17, 2017 12:09 AM
HermanTheGerman
1947 and Older Ford Trucks
Nov 1, 2015 01:30 PM
reed1951
19
Jun 24, 2010 07:57 AM
226 flathead 6
Flathead V8 & Flathead 6
Feb 18, 2009 08:22 AM
john fin
Aug 1, 2007 08:46 AM
