Offroad & 4x4
Disk brake conversion on my 78' Bronc
Old Mar 3, 2011 | 05:17 PM
alpha/omega's Avatar
alpha/omega
Nice work Jesse.
If I were you Id be flipping off those Moser shafts.
Old Mar 3, 2011 | 11:37 PM
fatdan460's Avatar
fatdan460
eff you, it makes sense to me right now, and thats all that matters.
Old Mar 4, 2011 | 12:52 AM
hav24wheel's Avatar
hav24wheel
Lmao!
Old Mar 4, 2011 | 06:20 AM
captain p4's Avatar
captain p4
You may want to consider moving the brackets backwards to make bleeding the brakes easier, you're about level now, so you're going to have to jack the front of the truck up for it to bleed right.. I think..
Old Mar 4, 2011 | 06:26 AM
hav24wheel's Avatar
hav24wheel
O Paul has a good point. Bleeder has to be at the highest point of the calliper
Old Mar 4, 2011 | 06:30 AM
captain p4's Avatar
captain p4
I'm not sure, but I think something goes wrong when they're turned upside down, ie going down a steep hill would put the caliper almost upside down.. I can't remember exactly what, but I think I remember reading something on pirate about it... either way, even if it doesn't affect how it works, it's going to be a PITA to bleed, so I'd def move them back some.
Old Mar 4, 2011 | 07:21 AM
ibleedblue1385's Avatar
ibleedblue1385
The bleeder is pretty much as high up right now as it can get, i don't think turning it any will raise it up more. Having it at the highest point allows the air bubbles to ride up and out the line, making it easier to bleed. I should be ok where its at, have to double check though.
Old Mar 4, 2011 | 10:57 AM
ibleedblue1385
Measured, marked, and cut brackets so they would sit 1/2" lower.
Much better:
Was able to turn the bracket slightly to allow the bleeder screw to be at its highest point. Its final resting place.
Old Mar 4, 2011 | 11:43 AM
captain p4's Avatar
captain p4
idk mang, I feel like the caliper needs to be vertical, or close to it for some reason. Does anyone else agree or am I crazy?
Old Mar 4, 2011 | 12:09 PM
hav24wheel's Avatar
hav24wheel
No, that should work fine Paul.
Old Mar 4, 2011 | 12:11 PM
fatdan460's Avatar
fatdan460
not to hijack, and semi related: paul what was the total on parts for your dads sterling disk swap, and for your post, how did they reccomend mounting the calipers?
i do remember reading something at some point that said they are supposed to be mounted at an angle or straight like you said, but don't recall the specifics. idk if it was something with gas disappation or heat or what, but i do remember something......
Old Mar 4, 2011 | 12:22 PM
hav24wheel's Avatar
hav24wheel
Race car drivers mount them as low as possible. So I don't see what it matters much as long as you can bleed the system. Some two wheel drive Fords back in the 70s had them mounted in front of the axle. So......
Old Mar 4, 2011 | 01:40 PM
  #28
alpha/omega
Dan, I dont know to the penny what Pauls dad has in his brakes but a close guess would be $300.
Old Mar 4, 2011 | 02:30 PM
  #29
captain p4's Avatar
captain p4
Something like that, 3-400 IIRC (though I can't RAC with these damn meds I'm on, can't wait to get off this ****. One more month ish)
Old Mar 4, 2011 | 02:54 PM
  #30
ibleedblue1385
Well both sides are done(tacked).
Now I need to figure out what lines to use. Perhaps the rubber lines from an s-10?
